Old 05-10-2013, 12:21 AM   #1 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
HeFf - '88 Honda CRX HF
A CRX named HeFf
Greetings,
I bought a 1988 Honda CRX HF back in Feb, 2013 off of Craigs...then parked it because we decided to move (as if I didn't have enough to do..) ... Anyhow, Now its May and I found a bit of time and money to see about little ol' HeFf (Hef is the name of the greatest publisher, he has great articles I love to read in his magazine and its an HF, which could be pronounced Heff, sooo...
HeFf, come to find out, is almost completely original!! There is 191,000 miles on the 1.5L, it smokes a bit, but overall runs ok. The oh-so-sought after overdrive 5 speed is intact and doing fine. The complete intake is still there, stock airbox and all...the exhaust has a different muffler (it is 25 years old) but even it is a conservative replacement, not a fart can here thankgoodness!
I started with fixing numerous oil leaks, now the clutch quit slipping.. guess it had oil on it. Glad to put that fix on hold, though there is a new clutch kit in the back of the car, thanks to former owner.
Seems all the lights work, though one headlight is, as we say in the south, a "coon hunting light"...up in the air. lol. I believe the guy mentioned his first 9 point deer was courtesy of HeFf.
The dashboard lights work too, a big plus...ever try to figure out a wiring mess under a dash? Ugh! I am really getting stoked about everything that works!
***UPDATE...Ladies and Gents, believe it or not....HeFf has a factory AIRCONDITIONER...AND IT WORKS! Now I don't know how many HF's came with a/c, but I bet its rare. Kinda odd a car that has no power brakes, steering or windows has air...lol.
Ok, moving along, I put on two new tires, frontend alignment and an oil/ antifreeze change, washed a few years of pollen off the paint.
To combat HeFf's smoke screen, I decided to try "honey oil", or restore in a bottle as some call it. Believe it or not, it actually works! The smoke is all but gone...hard to believe, I was always against this stuff, but not only does it not smoke much, it cranks a lot easier as well.
Lastly, I topped off the tank, a whole 5 gallons...and so far have driven 98 miles, the gauge is reading just a hair below full...still
I am just ecstatic the car is doing so well. I live 25 miles from work, and my taco was using way too much gas...and that's how I got here. More to come, stay tuned, base line gas mileage in a few more days...and immediately to be followed by a very easy Warm Air Intake..Carl.
Old 05-10-2013, 12:27 AM   #2 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
Disc Hub Caps?
Where can one score the stainless/plastic disc for hubcaps? Appreciate the leads...
Old 05-10-2013, 08:44 AM   #3 (permalink)
90 day: 57.73 mpg (US)
Congrats on getting the car going!
Heff will now have to watch out for bunnies as well.
Old 05-10-2013, 09:51 AM   #4 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
Light has HeFf is, bunnies might total it too...
Day 3 of HeFf's analysis...
A WAI is def needed, the lil' booger takes several miles to heat up.
As of today, it's down to 3/4 of a tank @ 130 miles since fill up...without accurate measurement, it looks like Im getting about 47 mpg...way below some estimates of 55+ mpg BUT I have been driving "regular", just to see where it will pan out before any mods, even driving changes.
It may suprise me when fill up time comes, Im just anxious to see...Im actually looking forward to buying gas! haha..
Old 05-10-2013, 12:26 PM   #5 (permalink)
When you do, it would be good to see a breakdown of the numbers (payback/savings) vs. your truck.
Old 05-10-2013, 12:40 PM   #6 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
Numbers are already making me happy.
I put $17 in HeFf three days ago, and still have 3/4 tank...my truck was averaging $12 a day to run, HeFf has saved me $19 in gas already...
The tag for HeFf was $20, and the tires were $30 each (13")... last time I bought it for my Taco, the tag was $200+ and the tires ran $225 each...now thats a number difference!
Old 05-10-2013, 04:18 PM   #7 (permalink)
A few things.
First, HeFf does have power-assisted brakes. Turn the engine off and pump the pedal a few times. You'll find that it gets very hard after a few pumps. That's because the vacuum has bled out of the booster.
Second, I suggest a grille-block for help in warming up the engine.
Don't completely trust the fuel gauge--the ones in my CRXes were pretty nonlinear, and would move much more slowly at the top and much more quickly near the bottom. It might be good to keep a gallon of gas in a can just in case the gauge is very far off...
The crxcommunity.com is a great BBS focused on the CRX. Lots of knowledge there, and it's less of a morass of locker-room talk and intolerance than many automotive BBSes.
Find and download the service manual for the car. There are PDFs available on-line in a few places. The Helm's manual is the same as the factory manual (as far as I can tell) and is one of the better workshop manuals that I have seen.
Careful with the 'Rex, they are not the most robust platforms in a collision! They sure are fun, and can be exceedingly efficient as you are finding.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
BlueCruxHF (05-10-2013)
Old 05-10-2013, 11:00 PM   #8 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
OMG I cant believe I didn't get this at first...Im usually pretty witty, just let this one go right over my head...durrrrrrr ...good one, dude.
Old 05-10-2013, 11:17 PM   #9 (permalink)
Passing the pump :)
BlueCruxHF's Avatar
Originally Posted by some_other_dave View Post
A few things.
-soD
Thanks!
I thought about the crash results before even buying it, and some really noticeable lighting front and back are already planned to help avoid the accident in the first place. The new leds are hard to miss, and a very big safety improvement over HeFf's old dim lights.
Your right about the brakes, I tried it and they do indeed have vacuum influence...but I don't see a regular vacuum booster like most cars. Odd..
The grill block was coming right after my WAI.
The factory was nice enough to stop the intake pipe right in front of the exhaust manifold...all I have to do is add a metal flex pipe, a hose clamp and Wa~La Warm Air Intake.
Another nod to you on keeping a gallon of gas with me...I don't have a clue how accurate it is.
Last but not least, I just hit 170 miles since top off, gauge now reads just below 3/4.
Old 05-11-2013, 11:33 PM   #10 (permalink)
The master cylinder is bolted to the booster, which is tucked into the firewall. You can see (just barely) in the upper-right of the following picture:
-soD
