Old 08-28-2009, 10:34 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
detached wing/spoiler above rear window?
Since the rear window of most cars is at a steep angle and do not flow air well, would a detached wing/spoiler help direct some air down to reattach to window/trunk? I saw that flow viz with the det. spoiler and just thought i would ask.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 08-28-2009, 11:24 PM   #2 (permalink)
90 day: 57.73 mpg (US)
Assuming you're talking about this sort of thing over the rear window...
Yes, the spoiler will direct flow down the rear window (they use them to keep windows clear of dust/water on some cars), but at the expense of increased drag from the defector itself.
On top of that, it probably increases projected / frontal area.
Old 08-29-2009, 02:43 AM   #3 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Not to mention creating plenty of lift...
Old 08-29-2009, 06:41 PM   #4 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I doubt that would create much lift. The angle of attack is much too high. Mostly just drag there.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 08-31-2009, 03:02 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
How to decie whether to remove rear spoiler
Tuft Testing - "Vortekz" vortex generators on 2003 Jetta Rear Window Deezler Aerodynamics 40 07-15-2017 02:56 AM
Removing "wind deflector" on 4runner rear window Quattro Aerodynamics 24 09-20-2014 09:56 AM
Window trim hurting aerodynamics? And a solution for my rear doors. Sean T. Aerodynamics 36 10-19-2008 08:58 PM
ScanGauge Rear Window Display? cfg83 Instrumentation 4 09-26-2008 01:31 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 01:33 AM
