Old 10-03-2014, 10:30 AM   #61 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
Today. This morning. Temps where 86 degrees celcius. Outside was 17 degrees celcius. It tooked 35 km to get it at 87degrees. Not higher. This afternoon. Temps outside are 25-26 degrees celcius. Its a hot day. A trip of 20km. 89 degrees celcius. No fan on. 30 minutes later. A trip of 40km with a lot of trafic jams. 89 degrees celcius. 5 times the fan went on and dropped temp down to 85 degrees.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 10-03-2014, 04:46 PM   #62 (permalink)
performance with economy
Originally Posted by TimV View Post
I was looking for water methanol injection, but on this site, nobody seems to have that install on a diesel, so i find nowhere proof if it actiually give a gain in fuel efficency.
There is a lot of info for gaining extra power, but i need a verry small nozle to give a verry low percentage of water/methanol per fuel when i accelerate.
Not a hole lot of water/methanol when you gun the trothle...
Then an other problem, the smallest nozzle i can find is a 50cc nozzle.
I drive 45 minutes to work, that is 40 km. The first 5km is with a cold engine, so no injection.
I P&G, so assume that i inject a bit more then half the time i drive. Make that 30 minutes for 40 km, for easy calculations.
I can drive 1200km on one tank. So injecting 900 minutes.
Smallest nozzle was 50cc, lets say it injects 60cc.
60cc/minute x 900 minutes = 0,06l/minute x 900 minutes = 54 liters.
Thats a hole lot of water, if you compare that i only burn 72 liters of diesel in that time.
So a smaller nozzle is needed or is this a correct volume of water injection?
Is there sombody who can tell me where i can find the info that i aim looking for?
Thanks
Water injection is mostly used on gasoline engines, it allows them to run a higher compression ratio and/or more ignition advance without incurring detonation. It could be used on a diesel engine for economy gains in theory, by allowing more injection advance without the attendant high pressure/temperature spikes, but setting up such a system would require a retune which costs dollars. The addition of methanol/water injection to a diesel can give a boost in power, but the methanol/distilled water costs money so dollar economy goes down mostly.
Old 10-03-2014, 04:57 PM   #63 (permalink)
Last weekend i went to a nearby country to do something with the car that probably nobody can gues. Teaser vid will be uploaded withing 5 days.
Still waiting for the vid!
I filled the car up before i went to that event.
30l for 511km. That is 5,87l/100km
That's great economy , my 93 TD uses close to double that amount of fuel, but I don't drive for economy
Old 10-03-2014, 11:51 PM   #64 (permalink)
@ blownoiler. I figuerd also out that the gains in milages probably are consumed by water and meth. So no further avtions in that direction.
I aim having some computerproblems for making that video. The files are superheavy. 20 seconds of video is like 1Gb of data...
Latest fill up is 5,3l/100km . 2 years ago. I drove also with 10l/100km :S
I can drift
Old 10-11-2014, 02:38 AM   #65 (permalink)
Alright. I filled up this morning. And like i tought about the previous fill up. That one was 2l short.
So together it is 2514km with 138.83l. Gives an average of 5.51l/100km. A brand new record
I can drift
Old 10-11-2014, 04:13 AM   #66 (permalink)
That's great economy TimV, I don't think that I could drive gently enough to make any substantial economy improvements, Well done!
Old 10-13-2014, 07:54 PM   #67 (permalink)
DieselMe's Avatar
This is not strictly true. You do not need a retune if you add water injection. You can do a pre-spray of a very small nozzle, I recommend 1gph (max 2 gph). then a 3-4gph nozzle after the intercooler. this will bring your intake temps and exhaust temps down (exhaust temps being the most important for a diesel). If you get a progressive kit - Devils own have the cheapest. then you will be able to set the spray progressively. I recommend 8-10psi start and full on max boost. If you add 10% methanol then I have read you will find economy gains (the VW boys love the water injection). This is caused by the water mixing with the hydroscopic methanol and becoming a cooling agent AND a fuel. Methanol also helps complete the diesel burn process.
Please see my post for up coming results:
http://ecomodder.com/forum/showthrea...ing-30238.html
Old 10-13-2014, 10:01 PM   #68 (permalink)
Dude, you have to add in the cost of the methanol to any economy/mileage sums, sure your diesel ($1.50 per litre here) use may go down, but methanol is an expensive fuel to buy, around $6.00 per litre from the local supermarket. Distilled water costs around the same as diesel, and from what I've learned over the years isn't a fuel, but does allow tuning changes to be made that can result in an increase in efficiency. Can you explain how the injected water mist will increase mileage please?
Old 10-13-2014, 10:57 PM   #69 (permalink)
DieselMe's Avatar
Methanol is $2/L here when I buy 40L (2x 20L drums). Methanol actually mixes with the water and become a fuel in itself. Like you say there is a cost for this, but you only add 10% to your water. Happily my window washer bottle is 5L so I add 500mL and it looks like the it will be 2.5L/tank fuel (~60L tank), so the cost is low. The VW tdi guys are seeing 8-12% fuel savings. But I am yet to prove this, and 'yes' it will take time. There is proof out there for the vw tdi cars, and the big trucks that tow 6.0L +. But I will need to prove this for myself also.
Many people are skeptical, and I'm not here to prove anything to anyone else. I want to increase my mileage because it's fun and because it's great for the environment. If you want to ignore this as a possible fuel saving mod, I'm okay with that. If you are genuinely interested, I'll be sharing my results when I have some solid data, so it'll be free info to everyone. Either way Happy eco-modding blownoiler!
Old 11-04-2014, 09:28 PM   #70 (permalink)
The vid is ready. Will be uploaded in a few houres.
Temps are still dropping. It is now 10 degrees celsius. Maybee going need to build a partially lower grill block.
Next mod to be: kill switch.
How do i kill a modern diesel the right way?
I can drift
