Go Back   EcoModder Forum > AltModding > Saving@Home
Old 03-07-2010, 01:52 PM   #1 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
DIY home energy monitor?
Has anyone here looked into creating a DIY home energy monitor? Prices for things like the T.E.D. are in the triple digits, and from my involvement in the EV space, I've learned magnetic current sensors can be had for $10.
For those of us who don't care about fancy internet connected features, How difficult would it be for the community to come up with a device that multiplies measured current by measured wall voltage to give a wattage value for the whole house?
~Jimbo
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Old 03-07-2010, 03:35 PM   #2 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Are there any fairly accurate current sensors that could interface with something like an Arduino?
Old 03-07-2010, 04:07 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
The tricky bit is getting a handle on the usage "on the cheap",
some electric meters come with a light that blinks every "x" watt hours, that would be relatively easy to monitor. The spinny disk kind might need some other setup, i.e. laser scanning or optical mouse type approach, to monitor the usage in real time.
Polling the system voltage (and current with a hall sensor) might be a more practical approach and easy to install.
but getting a handle on automatic monitoring of mechanical gauges has other uses, i.e. the gas meter and the water meter and ???
Old 03-07-2010, 04:24 PM   #4 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
There's a cool system that has wireless sensors (a la Kill-a-Watt) that you plug in wherever you have appliances or devices. The base station tells you usage at each appliance, and also can turn off the attached appliances remotely. They have a web page, iPhone app, etc. However, to keep from using more energy at each unit than you save, you'd have to design them carefully to use as little energy as possible. Hence my question about Arduino-based sensors.
Old 03-07-2010, 05:16 PM   #5 (permalink)
I think concentrating on a simple, instantaneous watt meter would be a good jumping off point. FOr the sake of intellectual curiosity, I'm going to go down in my basement and wrap a wire 'round a magnet to see if I can use it to get an readings off the mains.
Old 03-07-2010, 05:36 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
ya know, that isn't a horrible idea. A couple wraps around the main (wait for a dry spell first) and a voltage divider might be all you need to get an arduino sized signal. I'll have to think about it a bit.
But yah, ipods are pretty low in the priority list
Old 03-07-2010, 06:01 PM   #7 (permalink)
I wrapped laminated wire around a space heater cord, but it didn't seem to induce any readable voltage. This might actually require research *hides*
Old 03-07-2010, 07:29 PM   #8 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
Try asking over at hackaday.com:
Search Results home watt meter Hack a Day
They play around with this kind of stuff, or over at the forums at endless-sphere.
Old 03-07-2010, 09:22 PM   #9 (permalink)
Inductive pickups (without integration) are no longer accurate since many loads are nonlinear. The magnetic field produced by a current in a wire is proportional to the magnitude of the current, but the voltage induced in a coil of wire is proportional to the derivative (rate of change) of the magnetic field through the coil. That means that if the current is something besides a sine wave, integration must be done to undo the derivative distortion.
A better way is to use a Hall effect chip to sense the magnetic field. The output is directly proportional to the magnetic field (which is directly proportional to the current), which is exactly what we want.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-08-2010, 12:38 AM   #10 (permalink)
Good postings
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
New 1/2 house A/C time dremd Saving@Home 16 06-17-2010 10:11 PM
Monitor real time energy usage with Google Cd Saving@Home 18 09-18-2009 09:24 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
