Old 02-06-2010, 08:10 PM   #1 (permalink)
DIY Razor electric scooter?
So for a while, I've been wanting to DIY an electric razor style scooter. My goal of this project would be to make an affordable, extremely light and compact scooter with decent performance for its size.
I've worked a little bit with electronics, but have never attempted anything of this type.
To make it light and compact I'm trying to use as many RC parts as possible.
Parts list:
-Razor Pro scooter (about $50 and can handle a full adult easily)
-Turnigy 5AH 18.5v Li-po battery (~93 Whr's)
-Turnigy 900W electric motor (more power then I need. I plan to run it at 250-400 watts full throttle).
So now I'm not sure what else I should buy. I'm not very familiar with speed controllers and throttle controllers. I see some 250 and 350W electric scooter speed controllers on eBay, but I'm not sure exactly how they wire up.
Any tips or advice would be appreciated. And just so you know, I'm fully aware that with the battery and motor that I won't get very much range. 4 miles max according to my calculations. I could always rig up a second battery to get up to 8 miles of range. This project is meant to be fun, not necessarily practical for day to day use.
Old 02-07-2010, 08:06 PM   #2 (permalink)
Really... no posts? No one that has built an EV can chime in and advise me?
Old 02-07-2010, 09:23 PM   #3 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Why not just buy a ready made scooter and hop it up a bit? I had a Schwinn Stealth I ran at 2000 watts without any problem. Avoid the direct drive on those though, they're more trouble than its worth.
Old 02-07-2010, 11:07 PM   #4 (permalink)
1) Because it doesn't weigh 15lbs and fit into a backpack.
2) Because I can't build it myself.
The whole point of this project would be to gain experience about building an EV from scratch (a darn small one). Eventually I want to attemt an EV motorcycle and or car.
Old 02-08-2010, 12:55 AM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
What speed does that motor run at? lug it down to much and it's going to draw more amps then it is designed for and it will burn up, you might be better off just using that motor with a prop to push you as the gear box might be the largest cost of the project.
Old 02-08-2010, 01:02 AM   #6 (permalink)
I was planning on rigging things up like this:
The motor is rated at 500kv. If I power it with an 18.5v Li-po pack, then the motor should spin at ~9,000 RPM's.
I'm not going to use a gear box. Just a small chain or belt drive system. Not sure about the gearing and stuff like that...
A 1:10 gear ratio - 900 RPM would give a maximum speed of ~10mph.
A 1:5 gear ratio - 1,800 RPM would give a maxium speed of ~20mph.
So I'd probably gear it at about a 1:4 ratio or so. That way I could keep the motors RPM's down while cruzing at 10-15mph.
Thoughts?
Old 02-08-2010, 10:56 PM   #7 (permalink)
Ryland's Avatar
if you put to much of a load on that motor it is going to burn up, you want it to spin fast while it is working, it's designed to work with almost no load on start up and the load increases as the speed increases, so unless you plan to kick the scooter up to 15mph...
I would gear it to 8-10ph top speed, if it sees happy then re-gear it to go faster.
Old 02-09-2010, 08:24 AM   #8 (permalink)
Where would you put your back foot?
Old 02-09-2010, 07:57 PM   #9 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
i would do it. how much could that motor cost? if it burns up then i use a different one.
kick up the scooter to 7mph may not be too hard.
wear a helmet, in-case you can get to 10mph..
single person car thread
Old 03-28-2011, 07:53 AM   #10 (permalink)
The idea is great and should work. I would however kick start it first as the chain might snap under your load. I have watched the video and that scooter should really speed along. You will however need to come up with a solution for where to put your feet and the only solution i can think of is to have the engine at the back of the wheel or extend the foot rest
How to justify a scooter vs. a car NoCO2 Motorcycles / Scooters 43 09-14-2012 09:18 AM
AC vs DC for DIY MazdaMatt Fossil Fuel Free 15 03-06-2009 09:33 AM
Summer FE options - Scooter, bike assist, etc friedlbug Alternative Transportation 16 02-20-2009 01:41 AM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
DIY Solar charged electric scooter MetroMPG Fossil Fuel Free 4 01-09-2008 11:27 PM
