Old 06-19-2020, 03:28 PM   #51 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by elhigh View Post
The new e-AWD is going to make for some pretty cool overlander Prii in a few years, once they get old enough to get cheap. Somebody may be making supplemental battery packs to expand Prius e-range then, too, offsetting some of the economy lost to offroading mods
They are extremely disappointing from the test I saw. If the front wheels lose grip it couldn't push the car forward on flat ground with the rear wheels. It didn't make it to the cross side wheel traction test or the 3 wheels no traction portion of the test. Lol
https://youtu.be/UsxGatvvXUg
Sad bc in theory I wanted one. if anybody wants to a similar test rig to test out their not tradition AWD vehicles my company makes those conveyor sections in the video lmao I can get you some shipped out
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
bobo333 (06-23-2020)
Old 07-02-2020, 07:51 AM   #52 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
It seems my previous reply didn't post properly and has disappeared, bummer.
Im still having intermittent fuel problems, "premium" fuel seems to help the engine run more smoothly and powerfully than the cheap stuff but I still get P0171 'system too lean' and P3190 'poor engine power' every few days if I reset the codes.
I've borrowed an "engine data scan" computer from my dad which allows me to check and reset codes (basically a cheap scan gauge imitation). Unfortunately the gauge part doesn't work the way I expect it should and seems to randomly turn on and off whenever it likes rather than anything to do with the key or engine being on or running. I still want to get a proper Bluetooth module so I can use the Prius apps.
Leading up to my current road trip I finished off the towbar and rear carrier:
I also found a whole bunch of old election signs, so many corflute creations are in my future, the first of which is some window covers for this camping trip.
Halfway through the 12 hour voyage to the High Country I decided to do some exploring on the back streets and wound up running out of gravel road as it turned to clay very quickly.
After many hours of digging the sticky clay out from the rear wheel arches to allow the wheels to turn again (only to have them clog back up within a few metres) the sun came up.
After many more hours of digging and skidding and dragging the clogged rear end along, a friendly farmer came by and helped me out with his tractor.
The second half of the trip was less eventful, and despite 15 hours of muddy hell and running the heater to keep out of the freezing outside temperatures I still managed 34mpg on this tank lol.
More coming soon.
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 07-02-2020, 08:03 AM   #53 (permalink)
Get a Jeep :-)
Old 07-02-2020, 08:08 AM   #54 (permalink)
Well that was completely pointless, why on earth did Toyota even make this if it can't do the most basic of AWD challenges?
After this weekends efforts I've decided I need an LSD or some kind of brake bias dial for the front wheels, going over an obstacle on a slight angle lifting weight off one front wheel renders drive completely useless unless you have decent forward momentum, despite this I got some good off-roading done in the Victorian High Country.
https://youtu.be/HRgCRhtINjs
Old 07-02-2020, 07:02 PM   #55 (permalink)
Reminds me of what Gurgel resorted on its Volkswagen-based SUVs, with 2 levers at each side of the parking brake in order to manually brake only one of the rear wheels at a time, even though it's way easier to implement on RWD vehicles using the parking brake cables than in a Prius. Getting an LSD specific for the Prius would be quite challenging, but it doesn't seem impossible. Have you already got in touch with Quaife? As long as a stock differential is provided for them to make a prototype, they can make LSDs for basically anything.
Old 07-02-2020, 11:56 PM   #56 (permalink)
This BlueTooth dongle works with the Prius apps to access the battery info. https://www.amazon.com/gp/product/B011NSX27A/
Only $11.99 USD. It's also OBD2 so it works with 1995 to 2004 vehicles instead of only 2004 and later vehicles with CAN like many other cheap Bluetooth dongles.
The Following User Says Thank You to Galane For This Useful Post:
bobo333 (07-03-2020)
Old 07-03-2020, 07:34 AM   #57 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 214.18 mpg (US)
Send a message via MSN to jakobnev
Maybe you could add a plate or something behind the rear wheels that scrapes the mud of the tire before it goes up the wheel arch?
The Following User Says Thank You to jakobnev For This Useful Post:
Old 07-03-2020, 06:06 PM   #58 (permalink)
I ordered a similar one on ebay when the whole virus debacle started and it never got delivered so I'm wary of trying again at the moment.
I was thinking that as I sat in the car waiting for the tractor to come and pull me out, I'm not sure how often I want to be driving in this kind of mud though, I didn't do this on purpose and I'd rather not do it again.
Old 07-03-2020, 07:11 PM   #59 (permalink)
Wouldn't a plate just make it harder to clean out?
https://frontstreet-wpengine.netdna-...0-1180x788.jpg
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
bobo333 (07-04-2020)
Old 07-04-2020, 01:38 AM   #60 (permalink)
I'd take it with a grain of salt too, since anything rubbing against the tyre could lead to a decrease to its lifespan.
