Old 06-16-2019, 07:40 AM   #271 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Maybe put some inner tube over the joint with zipties or even some hose clamps?
Old 06-16-2019, 08:04 AM   #272 (permalink)
Or use a kit specifically designed for the purpose?
https://www.amazon.com/Dorman-614-53.../dp/B000C0YACC
MetroMPG (06-17-2019)
Old 06-16-2019, 10:30 AM   #273 (permalink)
This is also a good way, i had forgotten all about those.
I used that type of kit once myself, easy and quick.
Old 06-17-2019, 10:13 AM   #274 (permalink)
90 day: 51.82 mpg (US)
Latest problem!
Misfire!
(Mot my engine pic)
I pulled the plugs and one electrode was quite worn down. It even seemed slightly loose, which I've never seen before in a spark plug.
I cleaned & re-gapped them all, plus tidied the electrodes in the dist cap & rotor. I'll swap in the plugs from my parts car's parts car (good thing I kept the engine) if they look decent.
Parking the irksome wee beastie SOON. 3 days & counting!
Xist (06-17-2019)
Old 06-17-2019, 12:41 PM   #275 (permalink)
I remember on my 1987 VW Golf, it was the left side CV joint boot that failed, because it was quite exposed. I learned the hard way about driving in deep snow (when I hadn't shoveled) and when cold temps made the rubber more brittle.
MetroMPG (05-20-2020)
Old 06-19-2019, 03:35 PM   #276 (permalink)
Variable spark plug gap! (TM)
I've never seen this before! The car started running like poop last week, so I checked the usual suspects and found one plug with a loose electrode.
Check the gap....
Right side up (how I hold it when gapping it):
Upside down (how it sits inside the engine):
No wonder I was struggling for 70 MPG on the last couple of trips.
ID:	26236   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Daox (06-20-2019), freebeard (06-19-2019)
Old 06-20-2019, 07:43 PM   #277 (permalink)
Retractable spark plug electrode! Sweet.
Old 06-20-2019, 09:02 PM   #278 (permalink)
I believe that he discovered something that shouldn't exist.
Old 06-25-2019, 12:08 PM   #279 (permalink)
best tank yet: 75 mpg US
I knew I was on to something with that variable spark plug gap. Who's with me??
The SG said only 71.5. I did my usual slow 3-click fill, so we'll see on the next fill if it was a bit short or not.
And, yes, I'm STILL driving this irksome thing. My insurance company didn't reply to a recent inquiry about changing cars, I and I haven't been pestering them enough.
The latest annoyance (aside from the CV joint): front end is starting to get rattly -- at least one inner tie rod going, based on a quick inspection.
Xist (07-05-2019)
Old 06-26-2019, 12:38 AM   #280 (permalink)
I'm rolling a '98 3/5 Metro now. Had a very interesting trip home what with the seized front brakes. Temporarily un-seized 'em and got home, should be about 50 mpg. I'll find out next fill. Poor thing has bad rust issues but the engine and trans run quite nice except for a low idle/stalling thing.
