Old 12-10-2009, 09:49 AM   #11 (permalink)
...beats walking...
Originally Posted by Christ View Post
If the electric water pump is ECU controlled, why would you need a t-stat at all?
I mean, the ECU could just shut off the pump and monitor temps until the pump needed to move the hot coolant.
Originally Posted by Old Tele man View Post
(servo-mechanical flow control or electric pump control)
...one "or" the other, not both!
Old 12-10-2009, 11:48 AM   #12 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Heater circuit. Most thermostats/housings have a bypass to allow coolant to circulate through the intake manifold, if applicable, and the heater core. Without a pump always pumping this either wouldn't happen or would circulate very slowly. I suppose a second small pump could be used for this.
Don
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 457 02-11-2022 03:57 AM
Article: adding a turbo to improve efficiency MetroMPG EcoModding Central 107 05-25-2012 07:50 PM
News: Denver launches "Driving change" program to increase efficiency MetroMPG Hypermiling / EcoDriver's Ed 4 03-13-2008 03:18 PM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
