I am selling my 86 Pontiac Fiero project. It currently has a 8" Prestolite motor in it. I chopped off the back end of the old gas motor and had it milled down and used that as my adapter so I could still use the clutch. I ran this car for about 3000 miles with this setup at 96 volts and a home-made resistive controller and had it well over 70mph. Put in a Kelly controller that went south when it got rained on with the trunk open during charging. Too many other projects so this one has to go. I have a tow bar for it so you can tow it home. The flywheel isn't balanced perfectly, so it does vibrate a little at high motor rpms. The front tires only hold air for about 2 days right now and it does need new rotors in the front. Interior is a little rough. The rims alone are worth $300. First $500 takes it. Located in Neenah, WI 54956.
PM me for more info.
Hondo
