Old 04-05-2013, 01:43 PM   #31 (permalink)
double down
Search the interwebs for mini cooper hub motors. A UK outfit built a cool looking Mini with motors in all 4 wheels, so there is precedence. Something like that could be put on the back of any front driver with out too much doing I'd imagine.
I've been investigating the pusher trailer idea for my bicycle, using a kid trailer a bike hub motor, and a couple 12 volt lead-acids, or maybe retrofitting a e-scooter deal. One of the reasons I like electrfying the trailer vs. the bike itself is the trailer could be unhitched and then no additional weight is on the bike, save for a couple feet of wire and a throttle. The advantage here on a car pusher would be on a highway trip you may want to leave the trailer home.
For less than what it would take to design and build a 1 wheel trailer with drive train and hitch there exists a thing that lets you tow a motorcycle by holding the front wheel on a thing in the receiver hitch. I like the idea of wiring a throttle to an electric motorcycle in tow to a throttle inside the car. Then you get a pusher trailer, and an independent EV. You could have a gas motorbike pushing an electric car too, if you already had the electric car.
Old 04-11-2013, 01:26 PM   #32 (permalink)
www.tow-ster.com
I awnted one of these, but my Valkyrie is too heavy.
Old 04-11-2013, 09:18 PM   #33 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
And man did that thing look terribly cobbled!
Too bad real reliable hub motors don't yet exist at a hobbiest level, my cobalt has lots of room for batteries if I remove the spare, use a pair of hub motors and a Ford escape hybrid battery and instant prius. (sort of)
Old 04-11-2013, 10:41 PM   #34 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Like this PML unit?
Name:	pml-flightlink-electric-mini-cooper-wheel-hub-electric-motor-photo-232278-s-1280x782.jpg
Old 04-12-2013, 10:08 AM   #35 (permalink)
Thats how the "hybrid" car va tech had on display at the state fair was setup. It was a ford escape with a biodiesel subaroo drive train up front and an electric motor in the rear on the axles. Then a setup to go between the engine, motor, but required a lot of driver input to make work.
The gen 1 insight really is setting the bar as its easy to break 100 mpg. Why take a 17 mpg car, mod it to get 4 times that when you could just buy a better vehicle to start with and save you time and money?
Old 04-12-2013, 03:13 PM   #36 (permalink)
Yeah, most of the 1000 watt hub wheel motors I see on ebay are limited to 45 mph at full speed, then of course with it mounted hind you it would cause some problems with tight turns in parking lots. 1000 watts may not be enough to help you maitnain speed, but it should help you coast further and if used in combination of pulse n glide get you more fuel economy. An idea I had was to mount a small tire to it, mount it under the hood and use it to help spin the engine.
Old 04-24-2013, 12:03 PM   #37 (permalink)
I think a newer VW diesel would be great for this kind of experiment...especially since they did come with 4wd so the rear suspension should be easily modifiable.
I'm thinking perhaps a VW Jetta diesel wagon with the rear drivetrain from a VW Golf Synchro / Rallye and an electric motor in place of the driveshaft.
Old 08-20-2014, 09:18 AM   #38 (permalink)
Modder status:Noob Saibot
The Aquajet - '95 Saturn SL1
Team Saturn
90 day: 40 mpg (US)
just found this thread from the eco mods index. as soon as i started reading in a bit about how the 5th wheel works, i had the idea for rear wheel hub motors on my FWD 1995 Saturn SL1. After reading through, I decided that the info on this thread might be outdated, as far as hub motors go, so i looked around for 15 minutes and found this:
kellycontroller.com/brushless-hub-motors-c-21_62.html
any thoughts on the applicability of one of these?
I was looking at this one(kellycontroller.com/hub-motor-48v3kw-high-torquedisc-brake-p-158.html) specifically, as it mentions high torque
also, can anyone tell me whether or not i'd have to have a 13" rim for this thing, or if it's just telling me that the damned thing is 13" in diameter? my stock tires are 14s that i plan on changing to 15s or 16s. definately dont wanna pick out a motor that puts me a step in the wrong direction.
Sorry about the absence of links... im a newb... T-T
Old 08-20-2014, 09:29 AM   #39 (permalink)
90 day: 51.82 mpg (US)
Looks to me like those hub motors are meant for scooters/motorcycles. Nothing there appears to be a "bolt on" automotive type hub.
Old 08-20-2014, 01:13 PM   #40 (permalink)
rmay635703's Avatar
Read this thread (the whole thing)
Mira-Inboard Hub Motors - DIY Electric Car Forums
You need to install the motor(s) and modify them in exactly the way Ripperton demonstrates and then they will be usuable on a lightweight vehicle
Never mind he is the only person I know of to find an automotive use for these scooter motors.
Good Luck
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
MetroMPG (08-20-2014)
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
DIY Chevy Avalanche conversion to parallel hybrid MetroMPG Hybrids 2 12-01-2007 10:00 PM
