Old 10-14-2008, 07:36 AM   #1 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Electric Pusher prop?
theshreves.com - Project: Prop Car
Electric pusher props can generate a pretty fast air flow. Some of the little RC model airplanes I've seen can fly over 80 MPH with a tiny prop driven by a bushless motor. Those little fans can blow your hat off from 50 feet away!
Anyways, my question of the day has to do with toaster shaped cars like vans or square back SUVs (like my CRV).
What if, I had a 3' pusher prop mounted in the center of the rear hatch?
And once I got out on the highway, I turned on about 10 HP of thrust?
How would blasting the area of turbulence & drag with prop air effect the over-all cd of a van or CRV?
I already have an idea what would happen to my MPG...
Edit:
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 10-14-2008, 08:39 AM   #2 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
I guess you could start by looking at these.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 10-14-2008, 09:13 AM   #3 (permalink)
Those are pretty low profile in the front, except for the people..
My question is what effect would a pusher prop (or even a rack of ducted fans) have on the cd of an SUV or van.
If the air-mover was mounted in the center of the back of a square shaped van, would it help the cd ??
Cheers,
Rich
Old 10-14-2008, 09:34 AM   #4 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
That is a very ... yes it is a question. You may want to look into the legality of having whirling blades of death on the back of your vehicle first.
Being able to tell whether or not it helps Cd would be difficult to tell without a windtunnel as the extra propulsion would first need to be calculated out from the drag forces. Then to see if its worth it is to compare fuel consumption of standard vs possibly lower drag but with extra energy consumption.
I'd love to see the test.
Old 10-14-2008, 10:01 AM   #5 (permalink)
Dem old blades-o-death!
Yeah, after thinking about it for an extra 8 seconds, I decided that a bank of four ducted fans (16" OD) might work just as well.
Here's what they are using for fake jet engines in RC models these days.
If the impeller housing was made out of heavy gauge stuff, they would be safe enough.
Maybe use 4 of these motors..?.
Battery Powered Systems
Cheers,
Rich
Old 10-14-2008, 10:30 AM   #6 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
Beer usualy adds a lot of weight to those boats...yet they are still pretty fast...lack of teeth must be a pretty efficent weight reduction.
Old 10-14-2008, 11:57 AM   #7 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
It could be run on a secondary battery that was charged at home. Can we say plug in hybrid?
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 10-14-2008, 08:01 PM   #8 (permalink)
That's where my mind has been lately. How to convert my CR-V into a plug-in mild-hybrid.?.
Even with all the hardware (old 4WD setup) I've got to work with, it's still gonna be a biaash to get a pre-charged battery pack to deliver me some better MPG out of the old V..
But, could a motor like the Mars ME-0708 PM Pancake 12-48 VDC Brushed
deliver a thrust equal to 4 or 5 HP?
Assuming one could be installed in a 20" or 30" OD ducted fan? Modeled after the little RC Ducted Fans?
Humm, I might have get a MUCH bigger lathe..
Edit:
Looking at the plots in this RC EDF manual,
http://manuals.hobbico.com/gpm/gpmg3...anual-v1_1.pdf
it sure looks like the thrust goes up nicely with RPMs..
Maybe I should buy one of these and see if it's possible to scale it up..?.
(And, I could stick in on top on my little glider and make it say ZOOM!).
Cheers,
Rich
Last edited by Xringer; 10-14-2008 at 08:18 PM.. Reason: Adding some info about EDFs
Old 10-14-2008, 09:15 PM   #9 (permalink)
Dang!! Check out this mod..
Jet Beetle
Cheers,
Rich
Old 10-15-2008, 08:09 AM   #10 (permalink)
BBsGarage's Avatar
your also adding an abundance of weight that also needs to be pushed.
interesting idea though.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 30 04-23-2015 03:24 PM
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
“Revenge of the Electric Car” Coming in 2009 SVOboy EcoModder Blog Discussion 18 03-28-2012 07:24 PM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
Milwaukee Electric Car Building bennelson Fossil Fuel Free 5 10-20-2008 07:49 PM
