Old 06-08-2010, 01:28 PM   #41 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
lol, looks like you are real close can I suggest gluing the coupler back together and thread wrap it?
Old 06-08-2010, 01:51 PM   #42 (permalink)
90 day: 51.82 mpg (US)
Good idea. I had been considering a clamp/screw combo. Think it matters what kind of thread?
I've already epoxied it back together.
Version 1.1: I roughed up the inside of the shaft bore, applied a liberal amount of 2-part epoxy and put the shaft back in. The thought being: "make your own internal splines!" (C).
It lasted a little longer, but the epoxy sheared inside the coupler and it spun merrily around the input shaft.
It worked almost long enough for me to be sure whether a 1:1 motor:input shaft ratio at 24v will be enough for what I want. But not quite!
So I can adapt the coupler one more time and test again.
Also: if I'm willing to ditch the motor's commutator-end fan, I can turn the motor upside down and use the the external shaft instead of monkeying around with that little pump shaft and its weird interface to the motor.
Old 06-11-2010, 07:59 AM   #43 (permalink)
Honda ST1300 - '04 Honda ST1300
Great Project! I am considering doing the same with a small (22-23') sailboat and a couple of trolling motors. A couple of 50lb thrust trollers should be more than sufficient to move a little 2300lb boat. Lead acid batteries are dirt cheap at around $50/kwh! It's too bad I cant add them to the keel as ballast I have a small electric generator, just in case I get in trouble and run out of juice.
Ill be watching you're project closely!
Old 06-12-2010, 11:05 AM   #44 (permalink)
This is a great project. I am very interested in your results. I too have an OMC saildrive that's caused me great frustrations over the years; and have been looking into an electric option using the existing saildrive leg. Question: does the water pump need to be blocked and removed? Could the existing setup be left in and re-routed or utilized to provide cooling for the motor & controller?
Old 06-12-2010, 12:22 PM   #45 (permalink)
dcb
needs more cowbell
dcb's Avatar
...Think it matters what kind of thread?...
I think it would look cool wrapped in sinew
Old 07-21-2010, 09:47 PM   #46 (permalink)
Sorry for the lack of updates/progress here. Project is still on the to-do list, but I've been getting my sailing fix on other boats and using this one as my floating cottage. (Pied-a-l'eau?)
I removed the impeller from the input shaft, yes. Blocked the water intake externally, on the bottom of the lower unit outside the boat.
I suppose it could, yes. The challenge will be sealing the shaft, since in this boat at least, it's below the waterline.
I'll be back at this project in August, I figure.
Old 07-21-2010, 09:48 PM   #47 (permalink)
Cat gut, yes!
Old 07-22-2010, 03:55 AM   #48 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Generating power
With the underwater drive / propellar permantly out, you should install it so that you have two options. "free wheeling" or "Power generating mode".
The propellar will spin as you sail. If theres a free gear it will spinn without much resistance, but if the electric PM motor is fitted you could use that as a generator to charge your batt3ries.
Resistance while generating power would be higher, but I will proabably only reduce boatspeed with something like 1 knot.
And you would be making your own current for the batteries and the boat.
Thoughts on that ?
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 07-22-2010, 04:23 AM   #49 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Thoughts on that ?
Likely less than a knot. The limiting factor for boat speed is hull length at the water line. A little extra drag in the water will not substantial slow the boat, as once the hull comes up to it's theoretical limit the drag from trying to drive up onto the bow wake goes up exponentially.
For cruising boats there are commercial tow behind and drop down generators to keep the batteries topped, would be neat to see one piece of equipment pull double duty.
I looked at a lot of systems when I had my boat for dc generation without running an inboard diesel, that I mostly wanted to pull out and replace with a small electric motor for docking when conditions made docking under sail "challenging". I had well built a 32 foot ferro-cement full keel double ender. it was cutter rigged.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 07-24-2012, 04:12 PM   #50 (permalink)
Conclusion: project shelved; gasser re-installed
Very late update / wrap-up to this thread:
I ended up with too many land-based projects, so the boat was not used much in the previous 2 seasons -- it stayed on the hard last year in fact.
So, the conversion never got beyond testing the e-motor on the quick-n-dirty wooden lower unit mount.
This year, I sold a half-share in the boat to a couple I know, and they understandably wanted the gasser back in, rather than fussing with an experimental electric conversion.
So we tore down the motor this spring and replaced all the seals & gaskets. It went back in the boat before this year's launch and is working fine. The stinky, smoky, noisy (relatively powerful, long-range) 2-stroke lives again.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
Fun weekend project: solar assisted electric boat conversion MetroMPG Fossil Fuel Free 13 05-16-2011 02:58 AM
Honda C70 Passport Electric Conversion TedTheShred DIY / How-to 2 11-01-2009 08:02 PM
Extreme Electric Motorcycle conversion for Publicity/Charity bennelson Motorcycles / Scooters 5 11-18-2008 04:09 PM
