Old 10-12-2010, 11:22 PM   #11 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Seems pricey for what sounds like a minimal gain... $200 for PWM and $300 - $400 for a good electric pump?
Old 10-12-2010, 11:36 PM   #12 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
A forum member of another forum I belong to picked up about 10% on his motorcycle.
Old 10-13-2010, 07:16 AM   #13 (permalink)
So, just to be clear here (since we've gotten a little off track). We're agreeing that there is no benefit to warm up times with an electric pump.
Old 10-13-2010, 10:28 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by mechman600 View Post
Nope. When the thermostat is closed, a bypass is open.
I've never seen a cooling system schematic with such a bypass, do you have a link to an image or something? I've seen tiny pinholes in thermostats to allow a tiny bit of flow.
EDIT: yah, i see it now.
http://www.innerauto.com/Automotive_...ooling_System/
so the bypass is always flowing through the engine, it just flows less when the thermostat is open. My misconception
Try running a box fan, then throw something against it that blocks the air...
Interesting observcation. Do you think it would it be fair if power were measured by a kill-a-watt? I'll have to try that when I get home, both in cavitation and dead-head mode (lay it in the floor).
Old 10-13-2010, 10:29 AM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Yeah, the benefit would be minuscule at best.
Old 10-13-2010, 10:03 PM   #16 (permalink)
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
I agree with the logic, I think the only way one can sensibly reduce warm up times considerably, would be to reduce the amount of water in the system.
I.e. tiny radiator.
Old 10-13-2010, 11:20 PM   #17 (permalink)
One thing you need to keep in mind is the water pump does more than just move coolant between the engine and the radiator. As the engine warms up and the thermostat is still closed, the water pump is circulating coolant between the block and head to keep an even temperature across the whole engine. Your electric water pump would have to run at all times even when the engine is cold.
Old 10-14-2010, 02:30 AM   #18 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Old Mechanic View Post
Early model T Fords used a thermosiphon system with no water pump.
So did early John Deere tractors. No pump at all....thermostatic control came through the magic of physics. The hotter the water got in the engine, the more thermosiphoning would occur, and thus, more flow through the radiator. The only control you had was the crank that operated the rad shutters to adjust airflow through the rad. In order for this principle to work in a modern engine, you would need a HUGE rad with HUGE pipes. Modern cooling systems develop 40+ psi of pressure at redline - imagine the amount of flow that that equates to. The aforementioned model Ts and John Deeres had only 30 HP and radiators bigger than a Kenworth's. As far as economic savings go, I don't know. Us ecomodders are always trying the keep the revs low, where our water pumps aren't really doing a whole bunch anyway. Drag racers (aka high revvers) use electric pumps, but we're not drag racers.
Old 10-14-2010, 08:12 AM   #19 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I'll add that the thermostat has a tiny hole (or is never completely closed) to allow a small amount of coolant to circulate through it, instead of sitting in stagnant coolant. This is how it knows when to open.
Old 10-14-2010, 08:25 AM   #20 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
At work we've got distillation columns working on the thermosiphon principle.
It's a bit more complicated to get them going, but there's no issues with leaks, no worn out rotors, and no additional power is used to drive circulation.
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
Testing: WAI's effect on engine warm up Daox EcoModding Central 24 01-13-2011 09:41 PM
Greetings from Maryland! thedarave Introductions 7 10-14-2009 10:47 PM
Run Your Car on Water!!! (emulsion that is) Coyote X EcoModding Central 17 04-01-2009 01:20 AM
