Old 06-08-2021, 05:31 PM   #21 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I got my new ross tech cable and I am now able to see some things happening in the ID3. at 120 km/h speed the cars battery cooling circuit pump is not doing nothing. Nothing means there is no need for cooling for the battery. Cell temps were +26 to 27,5 celsius. That was with mechanical grill block in place.
will see tomorrow what happens with the electric motor circuit is there any coolant flow needed there or inverter circuit.
While charging the car with my 11kwh home charger there was 40% battery cooling needed. when outside temperatures were +22 celsius.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (06-09-2021), California98Civic (06-09-2021)
Old 06-08-2021, 07:47 PM   #22 (permalink)
'Not doing nothing". Typo, or do you mean it was doing nothing?
Old 06-09-2021, 02:44 AM   #23 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Unless there is no water flow the front radiator won't cool the battery as heat won't travel/conduct itself from battery to radiator. Ofcourse battery is air-cooled under the car. From the bottom plate surface area.
The Following User Says Thank You to Vekke For This Useful Post:
Old 06-09-2021, 10:03 AM   #24 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Really interesting, Vekke. It is broadly a little like an ICE at low load on a freeway: the radiator fan does not come on because aerodynamic pressure on the front of the car forces enough air through the radiator and the engine bay to cool the engine.
Old 06-09-2021, 02:03 PM   #25 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
I was talking about coolant pump of the battery pack. Engine is at the rear and batteries under the car. Under the hood is compressor and some other components.
Old 06-11-2021, 01:32 PM   #26 (permalink)
efficiency at high power
Originally Posted by cloowisa View Post
Electric drivetrains get less efficient at high power.
Both Toyota and Tesla have electric propulsion systems which have engineered out, previously experienced high power, high-rpm, eddy-current, back-emf, reluctance-related motor inefficiencies found in less sophisticated systems.
Take a look at ' IPM synchronous reluctance' ( IPM SynRM ) motors.
Piotrsko (06-12-2021)
