Old 05-23-2015, 11:12 PM   #11 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by dirtydave View Post
I had the same issue for a while. Got a deep cycle battery and upgraded the wires from the starter. Can key start after sitting a good 10 minutes with marker lights and turn signal on.
How did you upgrade starter wires? Larger gauge? How does it help? ... I also charge my 40ahr deep cycle battery at night. I have an on-board 25amp "smart charger"...
Old 05-24-2015, 02:53 PM   #12 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
yep larger gauge.
works very good.
google "big three upgrade"
Old 06-02-2015, 02:33 PM   #13 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
^^^ also note: Oxygen Free Copper (OFC) VS Copper Clad Aluminum (CCA) wiring. If you use CCA instead of OFC, you need to increase the gauge size to compensate! I used an amp-clamp and measured all my wiring to make sure I had the right gauge (or larger).
Old 06-12-2015, 01:47 PM   #14 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I never had an issue with the Anal Probe, but it should be said that letting the engine run for a mile to charge the battery is not going to ruin you, either. If you're having problems, just driving normally for a couple miles during the trip would be a great short-term solution before you go LED and PV.
And, please use your brake lights instead of the emergency brake. Cars have brake lights for a reason.
Old 06-13-2015, 06:36 PM   #15 (permalink)
The PRC.
Has anyone worked out the savings vs. Costs of eoc and battery charging ?
Old 06-15-2015, 03:59 AM   #16 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I just drove from home to Prague ~600km one way with EOCing almost the whole way. Headlights and markers turned on, radio on, ocasionally wipers due to rain in some places I was passing by. No issues with the accumulator. It was fully charged before I started my trip though. Accu is like 6-7 years old. And a bit bigger than it's needed and suggested by the factory for my VW Polo. That was the one I had anyway so since it's still going strong I have no intentions to change it.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 06-23-2015, 01:56 PM   #17 (permalink)
Honda Head
Rescue Toaster - '90 Honda Civic
90 day: 40.92 mpg (US)
keep in mind dropping the battery voltage constantly on a typical car battery will shorten its life. i know the mileage game is the goal but not at the expense of a 100$ battery(money, pollution/inconvenience). i would say from my own guesstimate a battery only needs about 30 mins of running time to FULLY charge, from like a dead/jumpstart situation. that being said, i gave up shutting my engine off at stops, unless i know they are lengthy, like a train crossing.
alternatively, EOC/no idling as much as you want in the day time, conservatively or lights off at night only. and if you must, just stop doing it for the last 15-20 mins of your drive home before you park, to let the battery recover
Old 06-23-2015, 08:15 PM   #18 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I'll save around $500 in my first year of EOC/ idle stop with EMMA. If the cost of a product is roughly indicative of how much pollution results from it's manufacture (obviously you can't apply this theory to every product), then a $100 battery is a small price to pay. I'd guess the battery will go on another two years at least, when it will be replaced by my 5 year OEM warranty. Even in normal use, modern car batteries seem unlikely to make it much past 3 years.
There's also inconvenience in making six extra fuel stops a year.
YMMV
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
UltArc (06-25-2015)
Old 06-23-2015, 09:25 PM   #19 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
As a link...
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-24-2015, 03:31 PM   #20 (permalink)
The PRC.
I've never had to buy a battery so I don't know the costs there. I did have a bad alternator which nearly killed a battery but that car was sold with the same unit in it and starting first thing every morning.
