Old 05-21-2010, 07:41 PM   #51 (permalink)
Prototype builder
jason1973tl's Avatar
Big Vic - '03 Ford Crown VIctoria LX
90 day: 21.92 mpg (US)
Thanks for the help
Noob here. Just want to say thanks. I am working on a 2f1r RT project and the links you guys post are great. Lots of useful information.
I only have 2 posts so far, so it won't let me send a link;but if you go to the diyelectriccar website there is a guy on there building a three wheeler user name is 80n541. Anywhoo, he actually is building his using a wire mesh which he then covered started to cover in fiberglass I am assuming. It looks like a wonderful Idea, and you dont need wooden formers.
The Following User Says Thank You to jason1973tl For This Useful Post:
talldudenumber5 (08-15-2010)
Old 05-21-2010, 10:20 PM   #52 (permalink)
90 day: 51.82 mpg (US)
You can sort of get around the post restriction: just type the domain/path without the http:// part, and leave off the www as well. It won't be a live link but we can copy/paste it.
Old 05-22-2010, 08:59 AM   #53 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Honda Civic EX
90 day: 47.5 mpg (US)
This is as old as the internet. You guys can do this 'easily' but will take a LOT of hours! Good luck!
Old 05-22-2010, 03:01 PM   #54 (permalink)
three wheeler - DIY Electric Car Forums
Old 05-22-2010, 05:24 PM   #55 (permalink)
Prototype builder
Thats it....I haven't seen a picture of it completed so well. Its looking good.
Old 08-10-2010, 02:14 AM   #56 (permalink)
aerobrick - '04 Dodge Dakota Quad Cab SXT
Originally Posted by johnpr View Post
im doing that tomorrow on my civic, i will be doing the grill block and filling the fog light areas (i dont have fog lights) but i will be making them removable and held on by double sided tape.
what did you use to try to sculpt, i am going to use a small saw and a grating type planer (an art student recomended that so i will try it)
What do you use as a "mold release"? If you spray fill the fog light area how will you get the foam out?
Don
Old 08-10-2010, 11:39 AM   #57 (permalink)
Quasi-Modder
Why don't you go into the kitchen and swipe your wives plastic wrap. It work great for fiberglass work; it should also work for foam.
Old 08-15-2010, 01:20 PM   #58 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
Okay, so I have some knowledge of this stuff, I guess I did learn something useful at art school...
First off you need to asses the part you want. If your filling in a fog light for example, you will have better results from a mold than from filling it into the car, as the mold can be horizontal. This stuff is effected by gravity, to get around that you need to set up some cardboard so when it expands it will only be able to go up, i.e. make the hole your filling into something that would hold water up to the top (but it can have little gaps which wouldn't actually hold water).
Mold releases are tricky with this stuff, as it really sticks to everything. In fact that is really it's biggest advantage. I think the best way to use this stuff is to make it permanent. It's quite flimsy when it's not stuck to anything. If you really want to play with removable plugs, some experimenting should be done. A thin coat of oil, grease, or Merphy's oil soap may prevent if from bonding. Try it out on your loan mower, worst case you'll have a mower with fins (which will make it go faster).
An alternative release method that has been mentioned is to put something like Al foil under it. If you do this the foil will stay with the plug forever. I'd worry about a small hole in the foil letting the foam stick to some paint somewhere. Cling rap might be a better approach for this reason.
Sculpting: If you have a removable plug it will be a little harder as it will be a flimsy little bit of foam, rather than a booger sticking out of your car. To rough cut it a saw with a very thin blade is best. An old hack-saw blade has worked for me in the past. It doesn't need to be all that sharp, and it's helpful if it's flexible. Just rap one end of the blade in tape for a handle. Don't try to get too far with the saw, just get the big goobs off. Next attack it with one of those cheese grader wood rasp things. Gently trim it down to the shape you want. Any f-ups can be filled in, just make sure nothing is sticking out past where you want it to be. Sanding the foam is pointless, just fill with Bondo and then sand, And repeat as necessary.
For bigger parts, like a new bumper, fiberglass cloth is a good way to make it strong.
the foam has almost no strength, but it's well attached, and it's light. The coating you put on it is what has the strength.
Hope this helps, if anyone has further questions on this stuff I'd be happy to fill in (no pun intended) the answer.
Edit:
Also for masking off around the fill spot cling rap would be good, But if it's a permanent plug I'd just sand it off where it drips, after all, I'd be painting near there anyway.
And for intentional bonds it would be good to rough up the paint with sand paper, and wipe it down with a strong solvent to remove dust and oils.
Redneck Repair forum
The Following User Says Thank You to Dr. Jerryrigger For This Useful Post:
NachtRitter (08-16-2010)
Old 08-16-2010, 04:53 PM   #59 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Thanks Dr. J!
Good summary. Does the poly fiberglass resin damage the poly foam?
Old 08-16-2010, 05:52 PM   #60 (permalink)
This I don't know, I would guess not, but a little testing is always a good idea with kind of thing. I suspect that an epoxy would be more of a "sure bet".
If the desired resin is a problem a coat of something in between can work well, as long as the sandwiched marital is strong enough, and adheres well to the foam and resin.
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
