Old 08-01-2023, 01:47 AM   #31 (permalink)
Originally Posted by rmay635703 View Post
Unlike the prime the volt does track electric and gas separately
Much better, especially considering the Volt was only available as a PHEV, while the Prius Prime had the regular Prius as a counterpart to provide at least some baseline to estimate efficiency while running without external charges.
Old 08-01-2023, 09:22 AM   #32 (permalink)
Well, the first 'mods' for this car are actually going to be on the house side of things. This is the current charging setup. It works, but it certainly isn't tidy or amazingly weather proof.
So, the first step was printing out one of these. Its just a J1772 plug holder and a wire wrap.
It'll mount to the side of the house something like this.
ID:	34005   Click image for larger version
ID:	34006   Click image for larger version
The Following 3 Users Say Thank You to Daox For This Useful Post:
aerohead (08-03-2023), ECO-AKJ (08-18-2023), rmay635703 (08-14-2023)
Old 08-01-2023, 12:37 PM   #33 (permalink)
90 day: 43.3 mpg (US)
If that outlet is on its own circuit, you can convert it to 240v just by swapping the breaker.
Not sure if your EVSE needs any mods or not to accept 240v. I know the Chevy Bolt EVSE requires no mods.
Daox (08-01-2023)
Old 08-01-2023, 01:00 PM   #34 (permalink)
Why not put it on one of the newel posts?
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
Daox (08-01-2023)
Old 08-01-2023, 10:28 PM   #35 (permalink)
The Volt EVSE does require internal mods because some of it runs on 120V. I have the video earlier in this thread that shows how to do it, and I'll get to that at some point.
That is a good idea and it very well may go there. I just wanted to get a shot of it.
The Following 2 Users Say Thank You to Daox For This Useful Post:
aerohead (08-03-2023), freebeard (08-01-2023)
Old 08-02-2023, 12:04 AM   #36 (permalink)
The Volt EVSE does require internal mods because some of it runs on 120V. I have the video earlier in this thread that shows how to do it, and I'll get to that at some point.of it.
Looks slightly easier than modding a Leaf EVSE. Leaf uses ring terminals instead of directly soldering to the board, but requires tearing out the built in varistor and replacing it with a janky 2 varistor setup wired in the plug itself.
Old 08-14-2023, 09:25 AM   #37 (permalink)
Is there any benefit to using a scangauge with the Volt?
Old 08-14-2023, 04:24 PM   #38 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Yes, but…
I would strongly recommend getting an antique windows 2000 laptop and the OBDII dongle so can can reset CEL and reprogram flags set in EV modules.
The Volt can be amazingly resilient and then something minor bricks the car (like using the wrong antifreeze or having a coolant sensor wire coorode or having not fully topped off battery coolant)
If you check out GM-volt forums you will find that previous owners had to use dashdaq because the scamguage would randomly trigger a cell. (No idea if this issue was affected by the year of the car or the software revisions provided by GM)
https://www.gm-volt.com/threads/scan...ry-amps.16224/
I never was brave enough to sort it out.
There is also a my green volt app that can let you look at stats under the hood.
The Volt is very strange in how it runs the motor making hyper miling on gas at times challenging. (It easily unlocks the motor from the simulated direct drive mode). It also runs hard then shuts off cycling in certain cases making your pedal inputs not match economy.
Sorry I don’t have a good answer to this.
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
aerohead (08-17-2023), Daox (08-14-2023)
Old 08-17-2023, 10:16 PM   #39 (permalink)
90 day: 57.73 mpg (US)
Just have to say: those are VERY funky railings!
Old 08-31-2023, 09:28 AM   #40 (permalink)
Haha, yup!
No major updates. Just posting that the lifetime mpg has indeed increased, and more than I would have expected! When I got it, it was at 63.3.
MetroMPG (08-31-2023), redpoint5 (08-31-2023)
