Old 12-02-2010, 02:22 PM   #1 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
2 questions
Should I buy a scan gauge for monitoring temps with using a grill block?
Is the general consensus that a grill block is for aero/streamling, or for just keeping air from entering the engine bay?
Seems that an exterior block would streamline/contain air while a block (behind the grill) would just block.
Old 12-02-2010, 03:17 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Or something similar.
Especially in hot weather it's good to keep an eye on the coolant temp.
It's doing both.
It streamlines the front by keeping more of the air out of the engine bay where it causes drag and cools the engine bay.
The air usually goes out of the engine bay through the wheel arcs or underneath the car, neither of which is good for aero.
More cold air means the engine runs cooler or takes longer to warm up, again, neither is good.
Old 12-02-2010, 03:39 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Yes. Modern temperature gauges are glorified "idiot lights". That is, they generally go to "normal" and just stay there. The Scanguage shows true temperature and a whole lot more. It helps you to figure out just how much of the grill you can block for outside temperatures and long hills. Grill block helps with aero and quicker warmup, both good things.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 12-02-2010, 04:12 PM   #4 (permalink)
euromodder's Avatar
Indeed.
The temp indicator on my car doesn't move from its normal position wether the coolant is 78 or 88 °C.
Old 12-02-2010, 07:59 PM   #5 (permalink)
What kind of car is it? Specifically, what model year? Cars before 1996 will most likely not work with the ScanGauge at all.
If your car is OBD-2 compliant, the the SG is a good idea. You can set up gauges on it for instantaneous MPG, trip MPG, and load value in addition to the coolant temp one. Those can help you change your driving to give you even better economy...
-soD
Old 12-02-2010, 08:08 PM   #6 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
i would get some way of reading coolant temps. A SG is nice and will help with MPG in other ways.
Look here for grill block info:
Grill block partial or full - EcoModder
Old 12-02-2010, 09:55 PM   #7 (permalink)
RSX2fast4mpg - '02 Acura RSX Type S
90 day: 38.22 mpg (US)
bubbatrucker - '98 Chevrolet K1500
90 day: 18.1 mpg (US)
My current grill block is just for heat retention, but I'm planning on making a more aero one over the winter. The grill block has definitely helped me keep the engine warmer when DFCO, and helps it warm up quicker. Without the SGII, I wouldn't have a clue whether it was working, good, bad or indifferent. My factory gauge doesn't look any different between about 168F and 213F, shown on the SG. Too me, that's critical information. Below 177F and my computer is still bumping up the idle to warm up the engine and if I was running any hotter on the high end, I'd probably cut back on my grill block (probably will have to in the summer).
In any case, the SGII is important for a lot of other things, including adjusting the nut behind the wheel. I'm always fascinated at how good a tool it is to teach you how to drive more efficiently. Just learning where you need to drive relative to other cars and trucks to enter their disrupted airflow and gain 3-5mpg while still maintaining reasonable following distance is vital information to have. I've had mine about two months and it has almost paid for itself in saved fuel costs.
ScanGauge Questions for a VW Diesel. Deezler Instrumentation 13 07-09-2010 07:42 PM
'97 Chevy Cavalier Install and Questions maverick21016 OpenGauge / MPGuino FE computer 3 05-21-2010 01:33 PM
M.S. Whittingham, inventor of Li-ion tech to speak locally. Questions? Wonderboy Fossil Fuel Free 17 12-22-2009 02:54 PM
Just a couple of questions... 97Cavalier General Efficiency Discussion 2 06-05-2008 10:31 AM
