Old 10-11-2015, 07:29 PM   #61 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
If you are still using regular steel wire from a MIG welder you would still need to protect the welded areas from rust with paint. I did this when I welded stainless bolts to the underside of my mirror delete plates. I have one spot weld that penetrated well enough that it rusted on the outside a bit.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 10-12-2015, 08:28 AM   #62 (permalink)
I could even weld with stainless wire. However, I'm not really looking to keep this car for forever. I'm just looking to fix up the gaping holes so it doesn't degrade further. At most I imagine I'll have it another 1-2 years.
Old 10-23-2015, 10:27 PM   #63 (permalink)
More work done. The driver's side is thankfully approaching the finish line. I hope to finish it up tomorrow.
So here is how we started tonight. Its difficult to see but there is a smaller hole behind the front tire, and then a long one behind that that needs new steel.
This is the forward hole.
I got it welded up and ground down. I didn't bother grinding down the welds you can't really see.
Then I shot it with primer.
Here is the forward side of the rear hole. Its quite long. I decided to patch the first part of it up to the little step you see.
I didn't get a shot of the sheet metal welded in, but I got it in, ground down, and primed.
ID:	18931   Click image for larger version
ID:	18932   Click image for larger version
ID:	18933   Click image for larger version
ID:	18934   Click image for larger version
Old 10-24-2015, 07:46 PM   #64 (permalink)
Wooo, yay another update. The driver's side rocker is nearly done. I just have to slap a coat of undercoating on it.
The first panel I put in tonight I got fancy with. I bent a nice lip on it so it matched the rest of the car. This took a while to fit up, but it matched pretty good. I just used my vise and bent it with my hands.
Tacked it in.
Welded it up and ground it down.
The second panel I didn't care about quite as much. You can't really tell a difference if its bent or not once you're standing by the car, so I blended it a little and kept most of it flat.
Weldy weldy.
Here is the last piece tacked into place.
And its all welded up, yay.
One more shot of primer on everything. In a few minutes I'll go back out to clean it up and shoot some undercoating on it. Just needed to kill some time until then so I posted the pics.
As mentioned, it looks far from perfect. The undercoating should really help smooth out things in the looks department. I also will still need to order some color matched paint for the door jam area as I got primer up there.
ID:	18942   Click image for larger version
ID:	18943   Click image for larger version
ID:	18944   Click image for larger version
ID:	18945   Click image for larger version
ID:	18947   Click image for larger version
ID:	18948   Click image for larger version
Old 10-24-2015, 09:41 PM   #65 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Looks good
Pressure Gradient Force
The Positive Side of the Number Line
Old 10-24-2015, 09:49 PM   #66 (permalink)
Thanks, its taken quite a bit more time than I hoped, but its at least halfway done!
Here is a bad picture of the rubberizing job. I'll have to get one in the daytime to get a good picture.
The Following User Says Thank You to Daox For This Useful Post:
deejaaa (10-24-2015)
Old 10-24-2015, 11:11 PM   #67 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
that looks great.
i think i could have saved my 81 truck if i would have had the skill, time, money and age. that was a long time ago.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 10-25-2015, 04:07 PM   #68 (permalink)
Here are some day time pictures. Its hard to see the detail... but thats how it really is when you look at it standing next to the car too.
I just ordered a color matched aerosol can for fixing up the primer area as well as the rear quarter panel and the spot on the hood.
ID:	18962   Click image for larger version
ID:	18963   Click image for larger version
Old 10-25-2015, 09:50 PM   #69 (permalink)
Not banned yet
deejaaa's Avatar
looks really good.
Old 10-26-2015, 09:08 AM   #70 (permalink)
90 day: 51.82 mpg (US)
Nice work. Years from now, that rebuilt rocker will be the last piece remaining of the whole car!
You should weld yourself a set of wheel covers!
