Old 03-30-2009, 01:13 AM   #11 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Originally Posted by snazzypants View Post
Unfortunately that site will only allow you to check out for orders >$25. But I know what to look for now. Thanks again
Seriously, your local NAPA or Carquest should have some in stock or if not can order them for you. Should cost lest than $2 ea. Probably cheaper if they're in stock. Local tire specialty stores (eg Goodyear) should also carry them.
Old 03-30-2009, 10:57 AM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
My coroplast covers, with a little cutout for the stems. They stick out less than 1/4 inch. They're still nearly flush, but I can fit a gauge and/or pump in there.
Old 03-30-2009, 02:25 PM   #13 (permalink)
90 day: 51.82 mpg (US)
Just a note: I bought a set of inexpensive "universal" plastic valve stem extensions, and 2 tires went flat overnight after screwing them on.
So now I do what Neil reccomends: I just screw one on to check/adjust pressure.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Aerodynamic hubcaps with holes for lugs/air valve? Bob64 Aerodynamics 8 04-01-2008 05:34 PM
Unreliable results measuring MPG / overinflation valve stem failure Cd EcoModding Central 9 03-31-2008 02:26 AM
SuperMID calibration methods ? / overinflation valve stem failure Cd EcoModding Central 8 03-30-2008 09:15 PM
Valve stem caps that blink when your pressure is low SVOboy EcoModding Central 1 12-23-2007 03:57 PM
