Old 02-28-2012, 07:20 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
what would you do?
I am taking one more trip to Dallas from Sacramento in May.(1775 miles over 2 1/2 days)
On my last trip I was able to get 32mpg with an 22 epa.
As you may know from previous posts I have done the following:
adjusted nut behind the wheel
scangauge
upsize tires (from 245/45/18 to 245/50/18 27.7" diameter)
43psi
nitro
IMPUL body kit (2" lower)
Lowered front end 1.25"
rear window spoiler
rear trunk spoiler
underbelly in front
underbelly in rear
Grill block behind grill
window tint (rear and rear sides)
window visors
Rear wheel skirts
So I have two thoughts:
1. I have been following the kammback threads and am concidering a clear kammback......
or....
could I acheive similar results by raising or lengthing the rear spoiler?
I was inspired by that windtunnel video with the new mb twoseater where the rear spoiler raised up....
however, I dont want ducttape it to the car. I want to try to make to look proffessional. I have some ideas but dont want to get started unless the group feels that it would help.
Also I have never figured out how to lay the 'templet' over the car to even begin to take measurements
2. I am going to run a lip or dam on the front. Havent worked uot the details because the car scrapes in the front sometimes so I dont want to do something now and drstroy it before the trip. there is about 5" from the ground to the bottom of the lip.
So do you think that doing a lip or dam is worth it for the trip?
Here is a side view of the car:
here is the software that VIIO did:
Here's a model of the air velocity affecting your car at 55mph - red is slow (drag/turbulence) and green/blue is full speed air (low drag = good).
you can see the lip that I had on for the last trip and the skirt in back
here is the front(less the required lic plate)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-28-2012, 08:02 PM   #2 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
reduce/or eliminate side mirrors as per legal in your state.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
The Following User Says Thank You to larrybuck For This Useful Post:
mcrews (02-28-2012)
Old 02-28-2012, 08:45 PM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
^^^right
Full belly pan, perhaps aluminum.
Wheel covers
front wheel skirts or partial skirts to fill the gaps
Exterior grille block
Kammback will help too. The spoiler on now probably isn't doing anything. You'd want one that sticks up far enough to hit the template.
The Following User Says Thank You to Sven7 For This Useful Post:
mcrews (02-28-2012)
Old 02-28-2012, 08:56 PM   #4 (permalink)
Knowing you are concerned about the appearance of the car, I'd suggest the spoiler. For better effectiveness, though, I'd suggest the Kammback.
mcrews (02-28-2012)
Old 02-28-2012, 09:21 PM   #5 (permalink)
mcrews's Avatar
Larry,
since I'm going for the kammback I dont want to eliminate the side mirrors or make 'non-factory' looking changes.
I have concidered some type of covering that would flair into the mirror.
I had gotten carried away one nite......
Thought about using fiberglass to mold something the would flow the air around it.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-28-2012, 09:28 PM   #6 (permalink)
mcrews's Avatar
[QUOTE=Sven7;289960]^^^right
Wheel covers
QUOTE]
Sven,
Thank you for the template layover!
I already have the front and rear pans.
I had removed the middle section and there was no decernable difference.
I am going to really look hard at the wheel covers on the front.
I just havent figured uot how two make the front partial skirt look 'proffesional enough'
I have tested the grill cover on front and back, no noticeable difference.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-28-2012, 09:41 PM   #7 (permalink)
Sven7's Avatar
Honestly, some moon covers on the wheels would look really good with that silver paint. I'd be happy to Photoshop them on if you like.
With some fiberglass fabbing you could have an OE-looking mirror delete panel.
An air dam up front probably won't be noticeable if it's behind the painted lip. On my Rabbit I mounted the front license plate under the bumper at a 45* angle and actually had people ask me if I had a front plate at all. It's amazing what people will miss, especially when they're standing right next to it looking down. In all likelyhood no one will notice a black air dam.
Old 02-28-2012, 10:19 PM   #8 (permalink)
mcrews's Avatar
I'm going to give the clear wheel covers one more shot.
http://ecomodder.com/forum/showthrea...5-11656-4.html
Zipties ar the way to go.
Vekke, I'd order some plugs but $$ is tight. I'm moving my daughter to texas at the same time.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-28-2012, 10:46 PM   #9 (permalink)
mcrews's Avatar
I took the overlayed pic and figured that it is 5inches from the top of the spoiler to the bottom of the kammback.
I have a small lip spoiler on the top of the window. I can use that as the anchor point for the top.
I'm thinking of using some polycarb and using a heat gun to curve the corners. Then fit the edges of the polycarb with some foam so that the kammback seals to the body.
I would probably build an aluminuum L bar frame that would have holes in it to hook small bungee straps to.
That way I could use the trunk and easily set the kammback on and off
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-29-2012, 01:16 AM   #10 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
I'm curious... nitro?
