Old 08-22-2014, 06:07 PM   #61 (permalink)
darcane's Avatar
Originally Posted by California98Civic View Post
Very pretty. 0.006 refers to valve lash/clearance? 0.006 would be tihter than spec just a hair, yes?
No, that's how much he had to shave off to get it within spec for flatness. He had a lot of heads he was working on. That is how he keeps track of his notes...
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
California98Civic (08-22-2014)
Old 08-22-2014, 10:13 PM   #62 (permalink)
TheManVan's Avatar
Very nice car man! And very tasteful upgrades! can't wait to see what you do with it!
The Following User Says Thank You to TheManVan For This Useful Post:
darcane (08-23-2014)
Old 08-23-2014, 03:01 AM   #63 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
I actually...didn't know there was an HX for this gen. Shame it was still only a 2-door, a family man like myself has a hard time justifying that for a DD. I do like the looks, inside and out, of this gen Civic.
I like the mods, agree they are tasteful, and I will say this, thanks for losing that stupid ass spoiler LOL!
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 09-10-2014, 01:38 PM   #64 (permalink)
darcane's Avatar
Welded up the exhaust:
And reassembled the motor. No pics this go around, looks the same as always except the power steering pump is now AWOL.
I did have a couple issues though. While it was torn apart, I replaced the brake pads. Well, the front calipers were leaking badly so I replaced those too. My 5-year-old son did a great job helping with bleeding the brakes. I got it all together and got the air out of the coolant and everything looked good. Put the radiator cap on and went for a drive... coolant was everywhere and it looked like my power steering was leaking, still.
Coolant turned out to be easy, the resonator for the intake bolts right above the upper radiator hose. Because of the orientation of the spring clamp on the hose, when I bolted down the resonator it pushed on the clamp. Rotated the clamp, and fixed.
Then I crawled under to check on the power steering leak and OH HOLY HELL THERE IS BRAKE FLUID ON ALL THE THINGS!!! Sure enough, my helpful 5-year old was also somewhat distracting and I didn't get the banjo bolt tightened down on the driver's side caliper. Cleaned it up and tightened the bolt.
Good to go.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following 2 Users Say Thank You to darcane For This Useful Post:
aerohead (09-24-2014), Daox (09-15-2014)
Old 09-13-2014, 04:09 PM   #65 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Admittedly I know very little about the seventh gen hx motors. The only seventh gen hx I have ever seen have been auto with CVT trans.
Not to go back into the old debate but having back pressure will increase torque, where as a free flowing exhaust is more effeceint at horse power which in terms of fuel effeceincy is not as relevant.
Whatever floats your boat works, I use to have an 01 ex with an integra muffler and it was less restrictive but still very efficient in noise reduction
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following User Says Thank You to Chrysler kid For This Useful Post:
Old 09-15-2014, 08:53 AM   #66 (permalink)
Glad to hear its getting fixed up. Are there any lingering issues or does that take care of everything?
Old 09-15-2014, 02:15 PM   #67 (permalink)
darcane's Avatar
Seems like it's all good. I've put about 300 miles on it and nothing new on it.
Unfortunately, my commuting routine also changed and I now have 5 miles added to my commute every morning to drop off my son now that he started kindergarten, and it is three steep hills each way (2 down 1 up there, and 2 up 1 down back) with stops/turns at the bottom of each. Consequently, that will do Bad Things™ to my fuel economy numbers.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 01-23-2015, 01:08 PM   #68 (permalink)
darcane's Avatar
Still trying to sort out the low fuel economy issue and not making any progress.
So I decided to tackle an easy issue. New headlights.
I've tried cleaning them and even when I put a lot of effort into it, they still looked crappy. $70 later, new lenses arrived at my door. I should have done this years ago. Almost literally the difference between night and day.
Old vs New lenses
All back together.
I'm probably at three times the light output I had yesterday, and even when I cleaned my old lenses, I wasn't anywhere close to the same light output.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 01-23-2015, 02:49 PM   #69 (permalink)
Hi,
Beautiful job! And very nice work!
There is not much space (metal) between cylinders on a Honda! I'm impressed that the head gasket seals at all.
My experience with valve jobs was that they lead to a ring job in 10,000 miles or so.
Hopefully, you will have a better experience.
Have you thought about some "trip strips" at the edge of your trunk lid and at the corners of your rear bumper?
Old 01-23-2015, 02:51 PM   #70 (permalink)
And you are correct, the farther one is from the exhaust pipe, the quieter is the car. I can't hear it at all in Atlanta! LOL
The Following User Says Thank You to MobilOne For This Useful Post:
darcane (01-23-2015)
