Old 11-24-2015, 10:20 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by arklan View Post
ok ....... what are they doing?
confused:
thanks
how can you have a pencil racing strip on such a bad ass car????/
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-24-2015, 10:30 PM   #12 (permalink)
Whatever they may actually be doing there, that's prime real estate for managing airflow in the front wheel-wells, one of the most problematic areas on a car.
Old 11-25-2015, 04:51 AM   #13 (permalink)
i spoke to a fellow today who said they scoop the air at the front and channel it up to outlits up at the windscreen, this creates downforce at the front and helps to push the air over the car when it hits the windscreen.
seems kind of counter intuitive for a car to go fast, but he said the lambo is designed for downforce rather than top speed like the veyron which also sounds legit.
the brakes must get pretty damn hot then
Old 11-25-2015, 05:09 AM   #14 (permalink)
It might also have something to do with downforce, but I'm not sure if it would be worth to channel the air up to the windscreen.
Old 11-25-2015, 03:35 PM   #15 (permalink)
downforce/top speed
Top speed can be a bragging right,but not so much if the customers are killing themselves in the car.
Here,the Countach shows it's dirty but stable form.
You really pay for the draggy wings
The Aventador loses the rear wing of the Countach for a 40 count drag reduction,but they're all over the road on track.
The Veyron ' begins' a bit cleaner than the Lamborghini
As velocity builds ir becomes dirtier to maintain stabilty
At 268 mph,Volkswagen doesn't want their rich clients dead in their car,so the Veyron gets really dirty
The flow ends up pretty hideous,but at least the driver lives to see another day
NachtRitter (11-25-2015), Piwoslaw (11-26-2015)
Old 11-25-2015, 04:10 PM   #16 (permalink)
I can see the vents at the base of the windshield. It makes sense to me. Massive amounts of air in at the stagnation point and a smaller vent at the base of the A-pillar.
The converging duct means the air out of the vents is moving faster and pulls any high pressure at the base of the windshield sideways.
As opposed to using the air for an air curtain over the wheelwell opening. The flow for brake cooling is just a plus.
Old 12-09-2015, 06:15 PM   #17 (permalink)
Aventador nose
The July,2013 MOTOR TREND had a small article about the Lambo on pg. 18.
They said the 'new nose and tail' improved aerodynamic efficiency by 50%,high-speed stability,and engine cooling.
freebeard (12-10-2015)
