View Poll Results: Do you use FE instrumentation
YES 35 64.81%
NO 19 35.19%
Voters: 54. You may not vote on this poll
Old 02-19-2008, 02:23 AM   #11 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
ScanGauge(s)
I Started out with an SG-I and upgraded to an SG-II after I wore it out
Basically, it's instant feedback on how you perceive the way you can drive the most efficiently. I can't quantify it, but mods + technique yield ~34% ^EPA. Feedback is a big part of that percentage.
Without the SG in other vehicles, the instant FE display is a good approximation too...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-19-2008, 02:33 AM   #12 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
What I've learned from this poll.... Most people that buy some form of instrumentation... don't use it.... seems off, but okay.
Maybe people without instrumentation voted too - as not be be left out?
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 02-19-2008, 02:38 AM   #13 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
Corrections Department
Correction: Can't edit right now
The %^EPA is closer to 25%...
RH77
_
_
Old 02-19-2008, 03:53 AM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
I use an SG I and it has made all the difference. If my car was pre-1996, I would definitely use a vacuum gauge. I do a ton of highway, but I don't have a breakdown of the %. My combined over (new) EPA is 41 / 27 = 1.5185 => 52% over EPA.
CarloSW2
American Solar Energy Society
Old 02-19-2008, 08:01 AM   #15 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I have no instrumentation beyond the oem tach I installed last March.
I'm told that a SuperMid would work but I'm not keen on tapping into the injector and speedo wiring to set it up.
If/when I replace this car I intend to insist on '96 and later so I can use a ScanGauge.
Current 90 day average (winter and mostly short hops) is 26% over EPA combined.
Lifetime average is 47% over EPA combined but it includes mostly highway.
Lifetime averate is 27% over EPA highway.
Coast long and prosper.
Old 02-19-2008, 09:38 AM   #16 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Originally Posted by AndrewJ View Post
For example, I don't P&G on the highway. My much lower Cd should really help me out in that area, and make P&G a very viable technique on the highway. But every time I try it, my next fillup sucks. I'm sure that there is a way for me to P&G on the highway and reap big gains, but I currently have no way of knowing about the finer points of my technique.
I've never been able to improve my mileage via P&G. I've tried it at various speed ranges and accelleration rates and have never been able to get mileage over what I get with my usual driving-with-load'ish driving technique (and usually it is worse with P&G). I suspect this is because the Honda engine is designed to run very efficiently at low power levels. The closest I get to P&G in my usual driving is on rolling terrain with too much elevation change for DWL to be practical, so I pulse the uphills and glide the downhills.
aerocivic.com
Old 02-19-2008, 09:49 AM   #17 (permalink)
In order to make pulse and glide efficient IMO you need a way of indicating weather your in open/closed loop mode. If your AFR is dropping down too low your loosing everything you just gained by pulsing. So, put up another point for instrumentation.
IMO, pulse and glide is where I've gained nearly all my mileage since my route is almost all highway. FYI, my previous percentages were per the old EPA, not even the new ones. The 2008 ratings would put me at 52% right now, and 72% come summer.
Old 02-19-2008, 12:31 PM   #18 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Interesting. I've just assumed that I was doing it wrong. Oh well, I won't be assuming anything for much longer. I'll have a SuperMID here in a week or so.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 02-19-2008, 10:03 PM   #19 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
Currently I'm not using anything. I have an 89 Honda wagon. I used a vacum gauge for quite a while and I had a voltmeter hooked up to the oxygen sensor. It was instructive, up to a point, but it wasn't as helpful as I'd like.
I'd like to get a way to monitor instant mileage, average mileage and timing, but with what I am getting, I can't see enough of a potential savings to justify, plus I need to keep every nickel as I can.
Old 02-19-2008, 11:20 PM   #20 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 Chevrolet S10 Crew Cab 4x4 LS
90 day: 20.44 mpg (US)
Currently do not, but am planning on getting either a scangaugeII or the "mid" thing as soon as I do some more researching on them(and when the IRS gives me back some of my money)
What features on your ULTIMATE fuel economy instrumentation? MetroMPG Instrumentation 41 05-12-2012 01:14 PM
News: Toyota to provide fuel economy instrumentation in all models MetroMPG General Efficiency Discussion 13 12-18-2009 06:40 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Nissan raises the bar: networked, onboard, "multiplayer" fuel economy instrumentation MetroMPG Instrumentation 12 02-07-2008 04:01 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
