Old 10-01-2016, 09:08 AM   #1 (permalink)
future
guys check on to the latest invention by infinity which will change a lot in the future of automotive industry.its an innovative technology which can increase both power and mileage. check on to variable compression ratio engine by infinity. sorry im not able to post links along with the thread dont know why???
The Following User Says Thank You to Jon.Alfredo@outlook.com For This Useful Post:
aerohead (10-01-2016)
Old 10-01-2016, 10:13 AM   #2 (permalink)
90 day: 57.12 mpg (US)
Yeah, we know
http://ecomodder.com/forum/showthrea...ine-34189.html
Infiniti is the luxury brand of the Nissan group.
You need to post 5 times before you can add links, as a means to avoid spambots.
Old 10-01-2016, 02:24 PM   #3 (permalink)
...beats walking...
Turbo charger with wastegate accomplishes same results with far fewer mechanical parts.
Old 10-01-2016, 04:09 PM   #4 (permalink)
No, it goes further. And the turbocharger is part of the plan, the variable compression ratio can compensate for the pressure variance the turbo would cause.
See Variable Compression Engine - How Infiniti VC-T Works.
Old 10-01-2016, 07:10 PM   #5 (permalink)
...beats walking...
Sorry, but one, single, spinning turbine is a FAR fewer parts-count than all those mechanical items just for ONE cylinder.
Old 10-01-2016, 07:31 PM   #6 (permalink)
Did you read into the link?
Old 10-01-2016, 07:46 PM   #7 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Its a cool idea but it doesn't seem to be that more power full and not that much more fuel efficient then todays GDI turbo engines.
The rod angle is nice and will help with side load but I just don't see any major issues with todays engines when it comes to side load?
Pressure Gradient Force
The Positive Side of the Number Line
Old 10-01-2016, 09:43 PM   #8 (permalink)
...beats walking...
ONE is << than MANY.
Old 10-02-2016, 02:15 AM   #9 (permalink)
One is CHEAPER than many.
And usually way less efficient.
Old 10-02-2016, 02:07 PM   #10 (permalink)
...beats walking...
...from the Jalopnik article:
"It seems to be a very clever system, though it does seem dramatically more complex than a single, dumb, forged piston rod. That may be why Nissan says the engine makes sense as a four and not a V6 or V8; the cost of all these articulated piston rods may be just too high."
[bold emphesis mine]
