Old 01-11-2009, 08:11 PM   #1 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
tire shoping
well after just over 40k miles my 30x 9.5 r15 bridgestone duelers a/t revo's are down to the tread wear indicator.
they seemed to roll at anything under 40 psi, but stuck to the road like glue. and were too soft, i got chunks on them going up a dirt road for about a mile.
now it is time for a replacement. i think i am gonna drop down to a 235/75 r 15 )almost stock (225/75 r15 is stock) but alot more choices.
this time i want a highway tread.
the tire i think i like is a General Grabber HTS
but havnt located them locally yet.
i did stop by sams club and was shown Radial Long Trail T/A by BFGoodrich.
for 440 installed, i have had them before(in a 31x10.50 r 15) but dont remember if i liked them.
i also liked the weird tread on the Fortera by goodyear.
but i dont know about them
i want a tire that is llr "ish" that can fit on my truck, that is driven on highway 99% of the time with no load on it. it also rains quiet abit here.
( if i need to tow or haul i got the 09)
so what are you all opinions? i am open for any tire that is good.
Old 01-12-2009, 12:58 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
taco -
Here are mine :
http://ecomodder.com/forum/showthrea...ires-2642.html
They do come in size 235/75 r 15 , but not rated at 51 PSI max like mine, only 44 PSI.
Take note :
The only problem is that on freeways that are grooved in the direction I am traveling, the car "wiggles", aka the tread tracks into the grooves like a phonograph needle and the car has a noticeable wiggle. I had a feeling this might happen, but no proof until after I bought the tires. Thank goodness my main commute only has this for maybe a mile or two. My wife's new GoodYear Eagle GT's do the same thing to a lesser extent.
The above is a minor annoyance (to me), but I think it would depend on what kind of highways you drive. I don't see grooves all the time. I would get these tires again.
Also, someone told me that you can have high-pressure rated valve stems installed when you get new tires. I think someone who worked at a tire store posted this. If I had known about that, I would have spefically requested it.
CarloSW2
American Solar Energy Society
Old 01-12-2009, 09:05 AM   #3 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Wouldn't going down to a narrower tire help FE quite a bit? Since you are going to run higher pressures a narrow tire won't roll over when cornering hard and will clear water much better than a wider tire.
I've gone to a much narrower snow tire and I haven't found a downside yet except the tires do feel a bit sloppy on dry pavement but I don't mind. If I want sharp handling I can put my autocross tires on during summer....
Ian
Old 01-12-2009, 10:38 AM   #4 (permalink)
Narrower vs stock width? Not "quite a bit".
Old 01-12-2009, 04:33 PM   #5 (permalink)
well a 235 = 9.4, and i had 9.5 so it is not really narrower.
30 tall(old) vs. 29.1(new) tall
so i want something to last. i got my revos on 8/28/06 and put a little over 40k on them, just going to work.
Old 01-12-2009, 06:00 PM   #6 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
The Green Seal Test showed the Long Trails to have the lowest rolling resistance coefficient of all the 16" truck tires. That is likely true on 15" truck-type tires.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-12-2009, 08:43 PM   #7 (permalink)
i know i read that, and i think i may go with those, but i was trolling tirerack and found the general tires.
long trails
--23--80%--6.6--7.1--6.9--7.3--8.2--7.5--6.7--6.2--5.6--7.9--7.8--8.1-37,852,348
general
--1--100%-8.3--9.2--9.3--9.1--9.4--9.1--8.8--8.5--8.1--8.9--8.7--9.1-273,442
under the highway all-season
but look at the mile difference.
but i think i may go with the better brand.
also the general have a treadware of 640 and weigh 34lbs
long trails
it dont even show them in my size but i have touched them?
Old 01-13-2009, 05:55 PM   #8 (permalink)
Big Dave's Avatar
No doubt about it, the Generals are better all-around tires in your size. Have you ever considered Goodyear Eagle SR-As? Yeah, they are car tires, but they are terrific all-around tires.
It really come down to one question: How important is low rolling resistance to you as a parameter of performance?
For fangs-out low rolling resistance in a bigger tire, the Long Trail has to be considered. If other parameters are more important, forget the Long Trail.
4" Slam
Old 01-13-2009, 06:22 PM   #9 (permalink)
i want distance, with good rolling resistance. like i said i drive over 30k a year.
the revos i have now i can fell the drag at anything under 35psi, like i said they were a soft tire also. u could dent them with your finger nail.
Old 01-14-2009, 11:55 PM   #10 (permalink)
well i ended up witl long trail touring, not the radial long trai. not what i exactly wanted but oh well. they seem to ride smoother than the revo's but i hope the height dont hurt my fe.
that is what i got.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 06:47 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
