Old 08-02-2009, 10:47 PM   #21 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Have you checked at AutoZone or anywhere to see if they have either in stock? You can ask about them, if they have them, just compare the spline counts, then you'll know for sure!
Old 08-02-2009, 10:52 PM   #22 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
No one seems to carry insight driveshafts, so no dice there. I doubt honda will have them in stock but I'll call and ask for posterity's sake tomorrow
Old 08-02-2009, 11:10 PM   #23 (permalink)
CRX -
Transmission circlip - 24mm
Insight -
Transmission circlip - 20mm
That tells me that the inboard joints are different, but I can't say yet for the outboard. They both use the same spindle (axle) nut, however.
Old 08-02-2009, 11:15 PM   #24 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yeah. I thought they might be the same also because I believe the brakes are nearly the same size and honda is pretty good and keeping things standard for ages. I wish I knew someone at honda who would have the specs...
Old 08-02-2009, 11:45 PM   #25 (permalink)
I'm not saying the hub side is different, just that the inboard (transmission side) is.
What's the engine code on the Insight?
Old 08-02-2009, 11:53 PM   #26 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yeah, I know what you're saying .
This is the best info I could find on the insight engine:
3-Mode VTEC (ECA)
Been developed for the Insight is Honda's first hybrid cars, DC to assist low-profile for mounting between a brushless motor and transmission, 995cc engine displacement of the cylinder and the three, tried a compact and lightweight.
VTEC-E, based on type and use the rocker arm ROLLERFORWARD, VTEC valve to narrow the angle due to the clip and roller pin coaxial switch, enabling rotation 3-Mode in the region to give rise to civil strong swirl did.
Other, reducing friction and is offset from the axis of the cylinder crankshaft, changes were made from lightweight materials fee.[1]
o ECA specifications
+ SOHC 12 valve VTEC PGM-FI
+ Displacement: 995cc
+ Inside diameter × stroke: 72.0 × 81.5
+ Horsepower: 50kW (70PS) / 5,700 rpm
+ Torque: 92N m (9.4kg m) / 4,800 rpm (ZE1 Honda Insight coupe)
Old 08-03-2009, 12:05 AM   #27 (permalink)
I'm guessing that was in Japanese, and you just hit it with something like BabelFish... which obviously didn't work out too well.
Old 08-03-2009, 12:08 AM   #28 (permalink)
Dartmouth 2010
SVOboy's Avatar
Nope, Wikipedia, but I assume that's how it got there to begin with.
So I guess the block says ECA?
Old 08-03-2009, 12:08 AM   #29 (permalink)
None of the part numbers are jiving... for any Civic versus the INsight.
Old 08-03-2009, 12:09 AM   #30 (permalink)
Dartmouth 2010
SVOboy's Avatar
O crap. I wonder if the hub can be swapped...Or maybe I can just disassemble the axles and reassemble them since the shafts are the right length...
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
What would you do to all-out modify (ecomod) a Honda Insight (gen 1)? MetroMPG Hybrids 25 11-26-2009 12:00 AM
News: Honda feeling pressure from Prius 3, planning to improve MPG of 2nd gen Insight MetroMPG Hybrids 14 07-31-2009 09:38 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Honda Insight gen 2 debut at paris auto show Daox General Efficiency Discussion 5 10-03-2008 11:00 PM
