Go Back   EcoModder Forum > Events & Meet-ups
Old 05-09-2012, 02:14 AM   #41 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
bellypan is done. I may fool around with the last 4 feet tomorrow, but it is a mess back there. Between the pumpkin and spare and rear spring arms and 4" exhaust, there is little room for anything but some small slices.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-09-2012, 02:12 PM   #42 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Update:
All engine wiring complete, working on gauge panel and Megasquirt wiring inside.
I'm not coasting, I'm shifting slowly.
Old 05-10-2012, 02:13 AM   #43 (permalink)
skyking's Avatar
The frame of the truck is not straight. It bends up near the forward leaf spring mounts.
To keep a frame jack point accessible, I made a jacking extension with 4" channel and 2" heavy angle. It is bolted to both the frame flange and the face of the frame, using existing and new bolt holes. After I fabbed those, I installed them and then jacked the truck on the new extensions.
For the framework, I used some galvanized channel from a surplus metals yard. Each 10' length weighs 2.8 pounds and I picked up 10 for $14.
I utilized 1/4" threaded rod and nuts, drilled and tapped the frame to stand off the channels.
This made the whole grid work adjustable. When I had it the way I wanted, I trimmed off the excess rod.
Some of the channel and rod "foundation".
Looking forward, you can see the crossmember is the lowest point.
Where I could not get a good parallel surface, I welded on tabs to drill through.
Here is the detail around the left A-frame. I can adjust the front framework lower if needed.
Same area, farther back and outboard. Note that I triangulated the channel to give it some stiffness.
front area is about done.
cloroplast is attached with self drilling #10 screws and 3/16" fender washers. It was installed back to front, with simple lap joints.
It is below the front frame, so a pocket is needed for hoisting up there. I could go back and make a frame extension in this area if I desire.
cut a window out below the muffler. It was the closest part to the pan, so I will let some of the engine cooling air out there.
same area looking forward. I did not go below the tank and went around it. I did not want to get the pan lower in the back under any circumstance, I wanted it to relieve pressure as it went aft. Going under the tank looked to be too much.
folded detail of front corner. This area will be behind a new bumper/spoiler but I had to finish it off and keep the truck going till then.
Today I brainstormed on that last 3 feet. I can go below the spare and close it in completely. I'll cut a door in the belly to get the spare out if needed. This got the angle to near 4 degrees.
I cannot maintain that to the outside edges due to the design of the boxes, so it will be tapered to the left and right.
you can see the taper in the framework here.
What the shop floor looked like after last night's flurry of trimming. I call it a "cloroblast".
I'm one sheet short
The back will go unskinned till I get back on the hoist and have the materials.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
Tango Charlie (05-10-2012)
Old 05-11-2012, 12:09 AM   #44 (permalink)
cool! Great pics!
the scientist geeks seem to think 10 degrees taper under the car is a good number, and I agree sloping downward at the back is probably a bad idea.
In the past two days my buddy got a LOT done on the hood, and it is mounted, and a bunch of body work done.
The windshield is cut down, and mounted into the body. Got to sit in my mounted seat, hold the steering wheel, look out the windshield, and make VROOM VROOM noises!!!
The back of the car has the hatch removable, and window openings cut out. We learned a lesson from an old pro about how to build the body flanges - we half built them, then the old pro showed us how it will never work the way we did it.
Oh well.
Meanwhile I made more money as a mechanic today then I paid my buddy for the work.
Old 05-11-2012, 10:59 AM   #45 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Skyking, you need to start a thread for your belly panel. It looks goooood.
-Terry
Old 05-11-2012, 11:03 AM   #46 (permalink)
skyking's Avatar
Done
http://ecomodder.com/forum/showthrea...tml#post306400
2003 TDI Beetle
2002 TDI Beetle
Old 05-14-2012, 01:22 AM   #47 (permalink)
skyking's Avatar
Got the electric fans in yesterday and used them today, pics to follow.
2003 TDI Beetle
2002 TDI Beetle
Old 05-15-2012, 01:30 AM   #48 (permalink)
more wokr on the hood, rear hatch is roughed in, rear windows purchased - should be in tomorrow.
dreaming of paint this week, but might be a stretch.....
Old 05-15-2012, 01:35 PM   #49 (permalink)
UFO
UFO's Avatar
Wiring 100% complete. Need to ring it out to make sure it's all correct so I don't fry my new ECM. Then the programming and tuning, should make June...
Old 05-24-2012, 11:18 PM   #50 (permalink)
June 5 is coming up.
My buddy got a round of body work done, then gell coated the body. Gosh, lots of stuff pops up when it is all one color and sort of shiny......
gonna pull it back to my shop tomorrow, and start on steering wheel, pedals, brakes, and wiring.
