Go Back   EcoModder Forum > Events & Meet-ups
Old 03-16-2012, 11:45 PM   #21 (permalink)
Sporty2k - '00 Kia Sportage 4x4 EX
90 day: 25.04 mpg (US)
Originally Posted by drmiller100 View Post
DC ampereage is load related. What this means is the electric pump for the PS won't take full amperage unless you are in a parking lot going very slow.
in that case, the battery will help you for the few seconds needed.
That makes sense, thank you for the feedback.
I still may go with the MR2's steering ECU, which incorporates a PWM controller that varies amperage output by vehicle speed, to give the Sporty's stock wiring some breathing room, as this is the daily driver.
Almost all the material I've found so far for the MR2 electric steering pump install is a (direct) hookup running at full amp. draw, so alternator life is a concern - a high-output (direct replacement) alternator is costly for the Sportage, $250-300, I'm hoping I can procure the the MR2 pump & controller for the same, or less.
I found this site: Toyota MR2 Power Steering System
that gives excellent info. on the ECU pinouts & hookup, very thankful to John Grigg for posting it.
Old 03-16-2012, 11:50 PM   #22 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
GottaCruise,
Not to derail your project, but did you consider merely taking the belt off the ps pump and looping the steering rack hoses? Or is the weight and balance of the Sportage such that it truly needs power steering?
Coast long and prosper.
Old 03-17-2012, 01:08 AM   #23 (permalink)
Originally Posted by brucepick View Post
GottaCruise,
Unfortunately, it does.. 20 years ago, I might have managed it, but as I get older, the more mechanical assistance is required.
The vehicle is just too heavy to be without power steering.
Old 03-25-2012, 10:16 AM   #24 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
I'll commit to getting some rear wheel fairings and a new belly pan fitted!
(By next weekend :P )
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
Old 03-29-2012, 12:07 AM   #25 (permalink)
ok you scabs, I pulled the trike out today. saw a few things I wanted cleaned up and fixed, and ATTACKED!
did the first 60 percent of the rear suspension - now need to mount it ot the chassis and finish it.
added some bracing to the frame in the engine bay, finished up a few mounts.
ordered some more resin. dug up anohter gallon of bondo.
what did you lazy bums do lately????
Old 03-30-2012, 09:57 AM   #26 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
Made progress on getting track car back to together. Made progress on selling Camry, also known as getting it ready to sell.
Twas a good week.
Old 03-30-2012, 09:22 PM   #27 (permalink)
brucepick's Avatar
Gen-1 Insights
Got the EPES just about fully installed. Still needs one more fuse and a box to mount the switches, but they're all hooked up.
Haven't gotten to the rear aero project. It's a challenge. This weekend I want to swap out the gearbox lube and advance the timing just a couple degrees... and I probably have a couple other relatively minor things on tap too.
Old 03-31-2012, 04:18 PM   #28 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Wheel bearings and rear brakes forced their way to the front of the list. Still collecting glass mat and resin.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 04-02-2012, 10:47 PM   #29 (permalink)
brucepick's Avatar
Gen-1 Insights
Yes. Well said, drmiller.
My Git'rDun items - hopefully completed in time for the Watkins Glen Green Grand Prix on April 20-21:
1) Finish installing the EPES: Externally Powered Electrical System with full complement of fuses, switches etc. My thread at: http://ecomodder.com/forum/showthrea...tor-20008.html
2) Finish redesigning/building/rebuilding the rear spoiler mod. Right now it's in the garage where it spent the winter. Warmer weather is upon us.
I got the second fuse added to the EPES. Still need to fully secure the battery in the trunk... I think I can, I think I can.....
Haven't touched the rear spoiler yet this year. Everything always seems to take longer than intended.
Old 04-02-2012, 11:21 PM   #30 (permalink)
got engine/trans mounted and mounts welded today. will have to redo them again. for the fifth time.
got suspension welded in and tack welded in. will have to redo some of that also.
got tires on it. It is a "roller" now. hood is too high - got to lower it 3 or 5 inches.
carmel in a month might be tough.
