Go Back   EcoModder Forum > Events & Meet-ups
Old 05-31-2012, 11:53 AM   #61 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Here is the mechanical portion of my dual fan installation.
I started out with a spare shroud. I needed the shroud to mount the large window washer fluid bottle. It is tall and complicated, has a low level sensor, and is already plumbed as my water/methanol system tank.
I used that same galvanized channel to make a bridge between the left and right sides.
The shroud was a freebie from a fellow dodge guy. it was cracked in the center from too many times of sitting on there while installing injectors, changing timing, etc
It was filthy greasy, and I only cleaned the left and right sides of it.
Once I had it braced, I cut away the nasty cracked part.
Now I had a place to start mounting the fans.
Fans on the rails.
I had to trim the fans to fit, and the remaining shroud. I mounted one edge with self tappers into the rail, and the bottom edge with the typical 1/4" threaded rod and nuts.
A chunk of folded coroplast sealed off the bottom edge.
I had to remove the oil filler from the front cover to install the fans, but I can work the whole assembly in there in one piece.
Things are tight!
I could leave the radiator hoses all connected. I will add another strap at the top for security, and cover that all up with a piece of scrap diamond plate. There is a gap at the front of the radiator that will take a wrench and drop it between the radiator and aftercooler. I have always wanted to close that up.
Belly pan--CHECK
Fillet fairings
Electric fans--CHECK
bumper
Grille
Testing aeroshell
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-01-2012, 08:25 PM   #62 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Didn't get the tail done, but did make quite a bit of progress tonight. Will post pics in my tail thread. I'll be in Montreal on the 10th so I'll have to have it finished by close of business Thursday, the 7th. I'd rather try to cross the border with a mostly completed car instead of how it looks now.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 06-04-2012, 09:02 PM   #63 (permalink)
Diesel
Ok, I'm as far as I'm going to go for a while. It is blue, just not the same blue as the rest of the car. Next run will probably to finish, finish the tail.
Boat tail project
Old 06-04-2012, 09:13 PM   #64 (permalink)
skyking's Avatar
Looks great man!
I'm done as far as any challenge is concerned. My truck is back in the transmission shop again. They did not get it right the first time and I won't have it back for days now.
2003 TDI Beetle
2002 TDI Beetle
Old 06-08-2012, 10:22 AM   #65 (permalink)
skyking's Avatar
Still totally derailed
I may get it back this afternoon, but I have to put all the bellypan back on before moving forward, ARGH!
2003 TDI Beetle
2002 TDI Beetle
Old 06-08-2012, 10:36 AM   #66 (permalink)
I'm declaring Jethro the winner!!! GREAT JOB!!!!!!!!!!!!
CONGRATULATIONS! Jethro is the DUDE!
