Old 10-12-2012, 12:05 AM   #1 (permalink)
Honda
Going from 15" to 14" rims on a Civic worth it?
I'm currently running 15" alloy rims on my 97 Civic EX with 195/55/15 tires. I'm currently averaging 38-40MPG (mostly all freeway). Would it be worth getting 14" rims for mpg gains? Secondly, I've got the stock 14" steelies, however, I'm not opposed to getting alloy rims if it will make a significant difference.
Thanks for any input.
Old 10-12-2012, 12:46 AM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
This tall tire test may give you some insight.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
cackalak (10-15-2012)
Old 10-12-2012, 09:35 AM   #3 (permalink)
90 day: 51.82 mpg (US)
If you went to a significantly narrower tire which also had less rolling resistance AND didn't reduce the overall diameter, sure it would help.
But you're asking about changing a pile of variables all at once (wheel weight, tire weight, rolling resistance, frontal area from tire width, aero drag differences of the wheels themselves, potential gearing changes from different circumferences), so it's pretty difficult to predict what will happen.
But if you already happened to have another set of tires, then you could do a comparison like Darrell did.
Old 10-12-2012, 10:31 AM   #4 (permalink)
Honda
Hey, thanks for the replies (and the link). There is another tire size that I overlooked--185/60/15. These are a tiny bit taller than the OEM size. I think I will try these first to see if it offers any benefits. They're cheaper, at least, so even at the same MPG, I will be saving money.
In the mean time, I will keep an eye out for 14" alloy rims and will test to see there is any difference. I have a 100 mile commute through the same highway everyday, so at least the testing environment will be consistent.
Hey, Sentra, how you achieve 50MPG in a rolling brick is beyond my comprehension!
Old 10-12-2012, 10:57 AM   #5 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Whatever setup you go with, the most important letters are: LRR.
Old 10-12-2012, 01:25 PM   #6 (permalink)
Honda
Pale - I'm buying Yoko Avid Touring tires, which I don't think are labeled LRR tires. They've got to be better than the current 205/50/15 Kumho ASX's, though. I hope I won't lose too much in the handling department going skinny. I'm also getting some camber wear, which should be better with the skinnier tires (need to get the toe adjusted again, though).
Old 10-12-2012, 07:39 PM   #7 (permalink)
14 inch wheels are about to be the next dead tire size.
Options for 14 inch tires are going to become few and more expensive over the coming years as 13 inch tires did.
Old 10-12-2012, 09:08 PM   #8 (permalink)
Considering the higher shock absortion from a tyre with the same final diameter in a smaller rim, a 14" ends up better than a 15" since it compensates a little the comfort issue in a lowered car.
Old 10-12-2012, 09:26 PM   #9 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Ugh.
Old 10-14-2012, 03:35 PM   #10 (permalink)
Honda
I'm sure this has been discussed, but have any of you run 7th gen Civic hybrid wheels?
07 Fit Sport.
