Old 01-19-2019, 06:58 PM   #11 (permalink)
The diesel engine wants some boost to be most efficient.
That way you have plenty of air to burn a little bit of fuel.
When I added the turbo on by diesel suburban I picked up at least 10% more fuel efficiency with out changing anything else.
If a gasoline engine is running boost then the engine is producing more power than it would at wide open throttle with no turbo.
Old 01-19-2019, 08:37 PM   #12 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Driving a rented 1.2L TSI Golf in Finland a few years ago, I noticed the instantaneous MPG on the factory instrumentation was the same no matter how I accelerated. So I used wide-open throttle to spend less time accelerating.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-23-2019, 06:11 AM   #13 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
On some cars the display maxes out. Ie my Fiat maxes out at 25l/100km, even though in the lower gears at least it's quite capable of using more.
Old 03-05-2019, 01:49 PM   #14 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by BSEM View Post
Do you know where I can look to find info for the most efficient engine RPM when cruising in 6th gear of my particular car?
Not for your specific car, but almost every car I've ever driven (gasoline) gets its best fuel economy at the lowest engine RPM you can reasonably drive in top gear. That's a good rule of thumb to follow.
For many examples, see:
Thread: Speed vs. MPG charts (post 'em if you got 'em)
Also, I second the recommendation of picking up some additional MPG instrumentation. You ideally want to see both instantaneous and trip average.
Another thing to pursue: if your automatic transmission has a "manual" mode, you can probably request earlier upshifts than the default "D" mode, and get into higher (fuel-saving) gears sooner.
EG., related topic:
Thread: "Short-shifting" a Jeep Patriot & Audi A4 CVT (forcing early "upshift") saves gas
And... belated welcome to the forum!
slowmover (03-06-2019)
