Old 11-25-2010, 11:32 PM   #1 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Grill Block
On a grill block, does the block have to be in front of the grill or could it be recessed (hidden) behind the actual grill?
Old 11-25-2010, 11:47 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Ideally...it should be flush on the front but fer "asthetics" you can put it on the back.
Old 11-27-2010, 10:54 PM   #3 (permalink)
In practical application it makes no difference at all. It's really a radiator block for use in winter. On one of my cars I am able simply to slip two thin sheets of formica in the space in front of the radiator. The minimal clearance is such that they will stay in place at any speed without falling out. If the temp gets too hot I simply remove them. It takes less than 30 seconds to place or remove them. Sweet & easy!
Old 11-27-2010, 11:35 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
In my opinion, the grill block is really more about aero than radiator blocking. Then again I run the grill block year round.
The Following User Says Thank You to SVOboy For This Useful Post:
Cd (11-27-2010)
Old 11-27-2010, 11:54 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If you want a 'stealth' grille block, you can place it directly behind ( flush with the back ) of the grille slats and paint it flat black.
Some grilles come blocked from the factory this way, and no one even notices.
For example, look closely at the grille on the Mazda 3 - a large portion is plugged :
Old 11-28-2010, 12:00 AM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
The farther that the block is from the actual grille, the more of an air pocket that is created. Placing the block at the radiator will help, but not as much as just behind the slats like in the picture above.
Old 11-28-2010, 12:03 AM   #7 (permalink)
That's sort of what I had in mind at first, a slot system so you could change out a plate with small/few holes for big/many holes.
On another thread I stated where after driving in the rain, I looked at the dry rain marks and the side areas seem to show the most pressure so I think I might do one flush but block it from the sides.
Old 11-28-2010, 11:50 AM   #8 (permalink)
Made my first template for the block, now I need a clear material that is bendable but pretty rigid and a good way to install the blocks, IE aesthetics in mind.
Old 11-28-2010, 01:20 PM   #9 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
see link in my signature box
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-28-2010, 02:45 PM   #10 (permalink)
If it does not matter, the behind the grill would be nice and stealthy.
Making a grooved holder for different plates would be very easy.
So is it the removal of air from getting in the engine bay, or the actual streamlining of the exterior, or is there a real difference in effectiveness between the two?
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
