Old 08-20-2009, 12:02 PM   #11 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I've often wondered about that temp sensor. I'd like to know more about how it's used.
Re: your intake. Isn't it behind the upper opening? Would it not be easier and more efficient to duct air from that? Maybe i'm missing something, correct me if i'm wrong! (EDIT, i just read your other thread. Scrub that statement i just made!)
Re: the lower grille block. My old grille mesh was clipped on from behind the bumper and was easy to push off. Then i cut some small pieces of coroplast and cut slots in them so they would push onto the existing hooks that the original grille mesh clipped onto. Then i made my grille block to the shape of the grille opening and screwed it to the coroplast. The whole thing is rock steady and all i need to do is find some better looking screws.
ollie
Old 08-20-2009, 01:06 PM   #12 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Re-reading my manuals, I might be wrong. I assumed that there's only 1 air temperature sensor, but in fact there are 2. The airflow meter has one in there - I think it's more likely that the engine would make the decision on the time the glowplugs are used based on that, not the environmental temperature sensor. Or even possibily the coolant temperature sensor. Or even the fuel temperature sensor. Or the ECU is wetting its finger and then sticking it up in the air.
All I know for sure is that the ECU uses a temperature sensor to make the decision, but I don't know which. It's just that the temperature sensor was called "environmental temperature sensor" which caused me to jump to conclusions.
The work's van was quite battered and have seen better days despite having only 40,000 miles on the clock and 3 years old, it's probably just worn out or have a different fault.
I'm going to retract everything I said about temperature sensors as I have found that I know less than I originally thought. Sorry about this!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 03:50 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
