Old 03-12-2009, 04:20 PM   #1 (permalink)
Racer XD - '06 Hyundi Elantra GT
90 day: 33.26 mpg (US)
Racer XD 2013 - '06 Hyundi Elantra GT
90 day: 31.48 mpg (US)
Racer XD 2014 - '06 Hyundi Elantra GT
Racer XD 2012 - '06 Hyundi Elantra GT
Racer XD 2011 - '06 Hyundi Elantra GT
Grill block over heat
I was testing a grill / bumper block using painters tape. I taped my whole front up covering all the holes. I left a small square hole for some air to still cool the radiator. Was driving on the free way and the temps started jumping up and down. My needle usually sits just under half temp and it was jumping up to almost max temp. On my scan gauge with out the block temps are around 183F+/-. With the block the max temp hit 213F. I want to keep an block on there but I am worried about my engine getting damaged to over heating. What is a safe temp range to look for with a block on and not hurting the engine?
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 03-12-2009, 06:00 PM   #2 (permalink)
Ive always been told - in general don't let the temperature go over 3/4 for too long.
YMMV
Old 03-12-2009, 06:26 PM   #3 (permalink)
over heat
I'm not comfortable allowing the engine to run at any temp over normal.I would progressively increase the size of the opening until "normal" temp is restored even if that requires eliminating the block altogether.
Old 03-12-2009, 06:40 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wildfire8 -
I agree with aerohead. I do allow about 10 degrees above normal, but over 10 degrees and I am watching it like a hawk. I installed a manual fan radiator switch, so I can "control" the temps without removing my grill block.
CarloSW2
American Solar Energy Society
Old 03-12-2009, 09:06 PM   #5 (permalink)
90 day: 51.82 mpg (US)
wildfire8: the temps were probably "jumping" up and down because your cooling fan was cycling to keep the engine from overheating.
You want to avoid that heat stress and the added electrical load from the fan.
So you need to size your block so the fan doesn't come on in normal use, or simply size it so the temp never goes over your normal operating temp. The ScanGauge is useful that way, since it records max temp experienced during the current trip.
Old 03-12-2009, 09:18 PM   #6 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
What's "too high" of a temperature? Without a grill block, my mazda hangs out at about 205 degrees on the highway in warm weather (70-80 degrees), but with the block in 20-30 degree weather, it barely hits 180 degrees. I think I'd have to hit 280 degrees for the temp gauge to get close to the "danger zone."
Old 03-13-2009, 05:09 AM   #7 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
205 is a good temp. my truck runs at 205-210 on the highway or in town (blasted mechanical fan). My GP is much much lower, around 175 or so. No idea why. I guess the aluminum block doesn't get hot much...? Totally weird since the 'stat is 185, or should be.... I have run the GP at 210 before, and not worried. It's the high end for the heat, but no where near the 250 red zone.
here's a nifty thought: Find an auto Protege at the junkers. Take it's fan. It's a two speed instead of one speed. Seriously. It'll get you a low speed help with the heavy up and down temp cycles. If you can get it to hold steady around 200 you're doing great.
Old 03-13-2009, 08:15 AM   #8 (permalink)
Hi,
Can you please post some pictures? Where is the one opening? Is it down low under the front bumper? The location of the opening is as important as the size of the opening.
I went from this:
to this, and so far I've had plenty good cooling:
Old 03-17-2009, 07:22 PM   #9 (permalink)
Sorry been busy.
I just did a tape mock up of a block on my bumper and grill. I had left an opening in front on the bumper. It was not that big.
I am now making a bumper block out of plexie glass. I got from lows from there scrap pile they where going to throw out. They happen to be the perfect size just needed to shape the edges for my bumper. And cut a hole for the fog light.
I am still working on it.
1st picture is of the stock car.
2nd picture is of the taped version of the block. I never took a picture so I just made a mock up drawing of what I had. The red is where the tape was. The part not taped on the right of the bumper is where my ram air tube is for my Intake. The other side was was covered all the way.
3rd picture everything that is in red on the 2nd is going to be be block with plexie glass but the hole is going to be bigger the red box is going to be the size of the hole.
I am going to just try it out with just the bumper for the first little bit. Then work on the grill.
Name:	front stock.jpg
ID:	2933   Click image for larger version
Name:	Taped test for grill-pumper block.jpg
ID:	2934   Click image for larger version
Name:	2nd try at block.jpg
Old 03-17-2009, 08:59 PM   #10 (permalink)
If you have a ScanGauge, you probably should ignore the car's temperature gauge, as they're notoriously inaccurate. Mine jumps to its "normal" reading at about 140 F on the ScanGauge, and doesn't budge when temps climb to 210 F.
I would try keeping temps in the 195-205 F range. Note that you should size the grill opening for hot weather, or make it adjustable. The standard opening is probably sized to allow adequate airflow when climbing mountains in hot weather.
aero, block, grill, heat, temp
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
I got worse fuel mileage with a grill block bombloader Aerodynamics 14 02-10-2009 04:16 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
