Old 03-08-2012, 11:06 PM   #1 (permalink)
Andrew63's Avatar
The Golden Lab - '05 Buick LeSabre Custom
90 day: 24.17 mpg (US)
Grill block / WAI side effect?
I installed a partial grill block on the Little Green Car. Now I notice that there is pinging. I don't know why, but I didn't think that a grillblock would cause a Warm Air Intake effect and require a timing adjustment.
Is this in line with your experience with grill blocks?
Old 03-09-2012, 12:48 AM   #2 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
In a year I don't think I have heard this described once. I think you probably are observing a coincidence, not a cause and effect relationship.
Andrew63 (03-09-2012)
Old 03-10-2012, 12:40 PM   #3 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The 96+ Hondas should all have knock sensors and automatically retard timing, if I'm not mistaken. Something funny is going on.
Andrew63 (03-11-2012)
Old 03-10-2012, 02:08 PM   #4 (permalink)
Cyborg ECU
Only the V-TEC models (EX and HX) had knock sensors in the early sixth gen, though maybe they all had them by 99-00. Mine is a 98 DX. No knock sensor. But the car does adjust ignition timing electronically, just not valve timing.
Old 03-10-2012, 05:27 PM   #5 (permalink)
I've watched intake temps on my Paseo with a FULL grill block. It might get warm air while sitting at a red light, but without a bellypan and more sealing the intake temps drop right down to ambient as you get moving. I should also mention my Paseo sucks intake air from the engine bay.
The Following User Says Thank You to Daox For This Useful Post:
Old 03-12-2012, 12:45 PM   #6 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Grill block
Did you make a hole for air intake flow?
I made a grill block for my turbodiesel car, but aldo made one opening on it, to allow cold air to get into admission.
Oldbeaver
Mercedes 300 D turbo 1993
The Following User Says Thank You to oldbeaver For This Useful Post:
Andrew63 (03-12-2012)
Old 03-12-2012, 08:58 PM   #7 (permalink)
Andrew63's Avatar
Intake air is taken from the engine compartment. I did not do a full block. I blocked the section that is in the bumper below the license plate mount; the opening above the bumper is completely open.
I suspect that LittleGreenCar needs a timing adjustment or a knock sensor.
Old 03-12-2012, 10:25 PM   #8 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
These Civics can also get a hard carbon buildup on the cylinder tops that the valves hit against when they open. It sounds a heck of a lot like "knock" or ping.
My wife and my carpool buddy both insisted my Civic was pinging. I tried retarding the timing to various degrees with no success. At one point I had it retarded so much that it ran poorly and gave a check engine light due to lousy combustion; I promptly set it back to a more normal amount of advance. Still made the noise but ran stronger.
Mine finally had enough valve trouble that it needed a head rebuild, and when my buddy got the head off I found a huge buildup of hardened carbon on all the cylinder tops. Easily a 1/16 inch thick of HARD stuff, which I removed with considerable effort. After the head rebuild the persistent "knock" was gone.
Coast long and prosper.
The Following 2 Users Say Thank You to brucepick For This Useful Post:
Andrew63 (03-14-2012), Pawtuckett (03-15-2012)
Old 03-13-2012, 02:03 AM   #9 (permalink)
ojman873's Avatar
Accent1 - '07 Hyundai Accent GLS
90 day: 28.88 mpg (US)
Send a message via AIM to ojman873
How do these deposits build up? Are there means to prevent or correct it without physically disassembling the head and/or rebuilding it? Is the problem unique (or uniquely worse) in Hondas?
Old 03-13-2012, 03:21 AM   #10 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
From what I have read, it seems it is a large side effect of idling too often. For how most people drive on ecomodder, it might be a fair idea to loose mpg once every 2-3 months and drive a bit harder on the car (freeway for example) to help clear out the engine.
Seafoam helps a TON with carbon build up.
Back on the main topic, I gained a WAI effect with my grill block, but prior to the last part of the block (lower) I sealed the hood and installed an upper grill block. I have no belly pan yet. Engine temps went from 202 to about 213-220 and intake temps went from about +5F over outside temp to around +50, not quite as hot as some WAIs, but still it is warmer. I notice no ping or timing changes via scan gauge, just a MPG increase and lower engine loads .
The Following User Says Thank You to ps2fixer For This Useful Post:
