Old 02-22-2010, 07:53 PM   #11 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Well the Fusion is kind of a sled. It could definitely use a belly pan, block heater and a grill block. I think it has great potential especially if you had a SG attached. Very solid ride. With the 6th gear auto the engine RPM is around 1750 at 60 MPH.
The TCU is learning my driving style and will now shift at 2000 rpm. The shift point are about 3-5 mph higher then I'm used to with an automatic but will let the MPH drop about 7 MPH before down shifting.
I picked it up yesterday and drove it 25 miles to the house. 38.3 MPG from a cold start. It was a perfect day with a light wind and 75 degrees. Did not get a chance to put air in the tires. They are rated at 51 PSI but only have 36 PSI in them. Left early this morning with temperature around 43 degrees. Lost about 3.6 MPG before the engine ever warmed up enough to reverse the downward trend. When I pulled into the chocks today it was reading 39.3 MPG.
From here the MPG will plummet. I have 4 days of 5 miles of gridlock to attack each way and the temps are suppose to be highs in the 30's with rain/snow. As slow as this thing warms up it will not be to temp before I get to destination. More to come....
"Judge a person by their questions rather than their answers."
Old 02-23-2010, 02:22 PM   #12 (permalink)
90 day: 51.82 mpg (US)
Yikes. 31 may be optimistic from the latest info & conditions!
Old 02-23-2010, 08:43 PM   #13 (permalink)
ECO-Evolution
Lazarus's Avatar
Ten miles today and 45 minutes travel time. AVG MPG has plummeted to 36.5 MPG. Rain/snow and southerners that can drive in it. Tomorrows suppose to be much better but still the car takes about 4 miles to warm up. Ouch.
Old 02-26-2010, 11:00 PM   #14 (permalink)
ECO-Evolution
Lazarus's Avatar
Finished up today. The total was 35.2 MPG. The high was 39.3 MPG mostly highway with a low dropping to 33.6 MPG for city driving for the tank avg.
I think you can do well with the car with a few simple mods and SG. One thing for sure is I have forgotten how intense eco-driving is. I was really wiped out after the long segments.
Old 02-27-2010, 11:39 AM   #15 (permalink)
CBR300R - '15 Honda CBR300R non-abs
90 day: 71.33 mpg (US)
Nice numbers. I wonder what could be pulled out of the hybrid fusions.
Old 02-28-2010, 11:53 PM   #16 (permalink)
Good work, Laz. Blew my guess out of the water (I should have known better).
Old 03-01-2010, 10:47 AM   #17 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Depending on speed,terrain, and temp, 50-62 MPG.
Old 03-01-2010, 04:15 PM   #18 (permalink)
ECO-Evolution
Lazarus's Avatar
I'm not sure how the hybrid system works in the Ford but if I applied the same % over EPA that I can get with a Prius it would be around 50 MPG plus or minus.
Aero Kit For Ford Fusion Hybrid srortega Aerodynamics 4 11-04-2009 07:05 PM
2009/10ish Ford Fusion Hybrid BrianAbington Hybrids 1 08-26-2009 09:32 PM
Hypermile a Ford Fusion hybrid: average 21 mph over 1446 miles = 81.5 mpg (US) MetroMPG Hybrids 25 05-04-2009 06:34 PM
2010 Ford Fusion Hybrid: Built for Ecodriving SVOboy EcoModder Blog Discussion 0 04-15-2009 05:50 PM
Ford Fusion Hybrid is Surprisingly Fuel Efficient SVOboy EcoModder Blog Discussion 3 12-24-2008 08:35 AM
