Old 08-03-2008, 09:04 PM   This thread is in the EcoModder Project Library | #1 (permalink)
homeworkhome53's Avatar
Workride - '07 Chevrolet Aveo5 SVE
90 day: 51.74 mpg (US)
Kill switch accomplished
I found a fuse in a box in the engine compartment marked fuel which I jumpered around with an inline fuse and switch which I mounted beside the manual gear shift. Works fine, but I can still hear my fuel pump running when in the off position, so I went back and looked some more and found a relay that is marked fuel pump in the same compartment. I think what I'm killing is the fuel injectors. When I throw the switch the car continues to run for a few moments. Just long enough to take it out of gear before it loses power. The instrument cluster continues to run and the odometer continues to total which is what I was looking for. The lights stay on which was a biggy for night driving.
homeworkhome53
Old 08-03-2008, 09:50 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Does it restart instantly? If you kill the fuel pump, it might have to repressurize before the car will start/run properly. Which could take a second or 2.
I interrupt my coil pickup signal from the distributor, and it still takes a heartbeat for the engine to stop running.
Old 08-04-2008, 06:50 AM   #3 (permalink)
The restart is instant as long as you reset the switch to on.
homewrokhome53
Old 08-04-2008, 12:06 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Interesting. I really need to get a kill switch going on my car, thanks for the inspiration,
Old 08-04-2008, 03:20 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
homeworkhome53 -
What SVOboy said. I gotta get my act together on this one.
CarloSW2
American Solar Energy Society
Old 08-04-2008, 03:42 PM   #6 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
Is this kill for coasting or theft protection? It's a bad idea to kill the fuel pump. If you are in a dangerous situation it takes a few key cycles to get going again and it could kill you.
Old 08-04-2008, 07:45 PM   #7 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I agree that not killing the fuel pump is probably ideal, actually. The faster you can restart the car when the need arises, the better.
I need to get a kill (and starting) switch, too. I have a relay laying around, and wiring diagrams, I'm just not sure what kind of current I'd need to deal with as far as selecting my switches. I suspect that I'm not dealing with anything serious if I go through the ignition circuit, but I am having a hard time finding a straight answer. I'm getting more brave, within the context of limiting it to backroads, with my EOC'ing, but switches would make it simpler.
Old 08-04-2008, 09:05 PM   #8 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Here is a write up I did on a metro kill switch but should be able to make it work for a lot more cars. It works really well restarts as soon as I let off button and bump start or crank it over.
http://ecomodder.com/forum/showthrea...html#post50913
Old 08-08-2008, 04:57 AM   #9 (permalink)
1997 Civic POS - '97 Honda Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
does anyone have the schematics to a jetski? Those have built in kill switches. You might find what they use to kill it would benefit us here. Of course, I could be talking out of my a$$.
IYAOYAS
Old 10-14-2008, 05:10 AM   #10 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.43 mpg (US)
Jetskis, (and motorcycles, and similar vehicles with kill switches built in to an FI system), have a safety loop, that when broken, stops the computer. On my Burgman in particular, this loop goes through the kill switch, side stand switch, and tip-over sensor.
Cars don't have this loop, so the same principles don't apply, unfortunately.
On this note, however, I'm looking at getting a Subaru Outback, anyone know how well their computers deal with having the injector power cut?
engine kill switch
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
DRL Kill Switch? gamer_jim EcoModding Central 8 06-05-2008 10:12 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
