06-30-2015, 06:32 PM
2016 Chevy Cruze: lower weight, better engine!
https://youtu.be/e0rYJSgVTto
I know, not many facts in the video, but it's so cool!
Ok, facts; Chevy claims the new 2016 Cruze to be 250Lbs Lighter, and the standard engine will be the previously optional 1.4L turbo I-4, which is claimed to give 40mpg hwy! Besides that, it should have an optional 1.6L diesel, and there are rumors of a hybrid! (Of course, the rumors you like never come true!)
"Ignorance is bliss, but only for the ignorant"-Hypermiler1995
The Following User Says Thank You to Hypermiler1995 For This Useful Post:
06-30-2015, 06:35 PM
Growin a stash
Minor correction: it's not the same 1.4L but actually an upgraded aluminum version.
I was shocked to read of a 12.5 compression ratio for the new Volt!
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following 2 Users Say Thank You to ME_Andy For This Useful Post:
06-30-2015, 06:49 PM
Even better!
I'm happy with what's going on in Chevy and Ford lately, lower weight and better engines!
06-30-2015, 08:58 PM
Shouldn't be too hard to lighten up the Cruze, its pretty much a tank for its size. Good to hear they're headed in the right direction though.
07-01-2015, 01:49 AM
Cyborg ECU
I saw a review claiming there would be a 2.0 turbo diesel, a 1.4 turbo, and a 1.5 ecotec engine. The last seems weak in power to weight ratio for US tastes (about 118 hp, 110 ft lbs torque, and 2700 lbs is kinda early 1990s Civic range). I'd like the weaker engine for the ecotec, but my countrymen want "horses"... turbo diesel is pretty exciting too. That would be fun to test drive.
07-01-2015, 09:54 AM
Thalmaturge
IIRC, in the past Cruze models, the 2.0T diesel has only been available as an automatic... I would guess this one will be the same, sadly.
Sam
07-01-2015, 11:02 AM
Furry Furfag
Mmmmmm 1.4 turbo... Too bad I don't believe in buying new cars.
07-01-2015, 11:36 AM
Cyborg ECU
Sam
I wonder if the transmissions are swappable mechanically without a plate and, if they are, whether the electronics would be so complex as to make the swap almost impossible?
Right?! Me too.
07-01-2015, 11:41 AM
#9 (permalink)
You can already get the Cruze with a 1.4L turbo.
07-01-2015, 11:43 AM
#10 (permalink)
Furry Furfag
Oh. :P
