Old 01-11-2012, 03:18 PM   #1 (permalink)
kompot - '99 VW Golf IV 1.9TDI AGR
hello all!
Hi.
My name's Patrick, I'm and engineer with masters degree with specialization in vehicles. Some time ago walking through the streets of Warsaw I saw Piwoslaw's car with the forum-badge. Have to say - didn't regret checking it after getting home
I got experience with piggyback engine calibration - did a master's thesis project running a petrol engine on a mixture of gasoline and ethanol. Did a bit of a try to chiptune my own car's engine, didn't put enough effort and bravery in it though I also had a great time being an intern in engine and chassis research lab. Now I'm back to some other things, but still interested in engines, chassis, aerodynamics and hypermiling (also racing - have some experience and successes in minor events chasing Swift GTIs in my lousy diesel ). Not sure if would run my own project but would be pleased if my knowledge helps anybody.
Cheers!
Old 01-11-2012, 03:39 PM   #2 (permalink)
Welcome to the site.
Old 01-11-2012, 03:57 PM   #3 (permalink)
welcome! more engineering experience is always a plus.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
Old 01-11-2012, 04:27 PM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Good for you! If the EM window sticker "saved at least one soul from fuel-hell" then it was worth the extra weight
Sounds like a few threads could use some of your expertise.
Not even a small project? Not even a grille block during the colder months? A small Kammback, barely noticeable to the untrained eye? Just a bit more in the tires? E?
Old 01-11-2012, 05:50 PM   #5 (permalink)
Great, looking forward to it
This is going to sound bad I only changed the tire pressure to mess with front and rear axle slip angles and, sometimes, took of the IC cover to lower the intake air temperature. Sorry, promise to make it up to you
Oh maybe I did some test on low 3,x bars (approx 50psi) but didn't like the feel. I'm as much into driving technique as in the engineering. Again, very sorry
Old 01-11-2012, 07:56 PM   #6 (permalink)
Green Canadian Eco-Egg
Oldskoolways's Avatar
New guy as well!
Good to see a couple of well intentioned engineers in here! Just signed up today myself... I'm also a mechanical engineer. Designed and built a Regenerative Braking Electric Bike with CVT trans for my senior project! Been messing around with fuel economy now for quite a bit and have been going to this site for quite awhile for info, finally got the nerve to sign up!
