Old 03-31-2012, 07:01 AM   #1 (permalink)
Hi from Poland with lupo 3L
Hello everywone,
I am Michal and I need help of someone who know how to adjust changed gear (5th) in Lupo 3L... New gear is not original(I took it from VW Polo 1.9sdi - slower 5th) and when I change into 5th it is automaticly change to N and I have to turn off the car and start again.
Can anybody help ?
Old 04-01-2012, 02:39 PM   #2 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Welcome! I think we have at least 3 very active people from your country here.
I would suggest that you post your question in the Ecomodding Central section.
Many active people seldom visit the Into section, due to being more interested
in the middle of the sandwich so to speak.
Sounds like a good car overall for high priced fuel.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 04-02-2012, 02:08 AM   #3 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Hi,
I have also a lupo 3L and long thread about its modifications.
So do you get the fifth gear on or does it just change to neutral when fifth should go in? Changing the gears should not effect the gear changing mechanism. Did you check thegearbox functioning with VAG com adaptation and clutch creep settings. That will thell you where the fault propably is. Probably some misangliments of that gear actuator.
Why did you put shorter fitft gear ratio?
How long did it take to change the gear and did you have to take the gearbox out?
https://www.linkedin.com/in/vesatiainen/
Developing next gen wheels and tires which will give 20% more range in Tesla Model Y.
Old 04-02-2012, 02:55 AM   #4 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi Michal,
Welcome here! I think reason for gearbox to change to N may be different, not the 5th gear ratio. Check everything else around gearbox, maybe connector, missing or mailfunctioning switch.
Good luck
Andrzej
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-02-2012, 08:22 AM   #5 (permalink)
Thanks for replies,
It's change to N a few seconds after 5th gear is on, it seems like car "thinking" what to do.
I did check faults by Vag and after this situation there are 2 faults of valves from acutator
I will try make adaptaion again.
Vekke I had to take out the gearbox becouse this gear was completely destroyed, cost of new 5th gear is terrible high so I use other for free
I spent two days on this work.
I can't belive too that problem is with gear ratio but I don't know what to do now
Old 04-02-2012, 02:04 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
So you need to do this test with vag com:
http://wiki.ross-tech.com/wiki/index...sion_%28085%29
Write step by step what you try to do and what the car does. So you put the fifth on in manual mode and it uses the gear two seconds and then pulls the clutch?
Did you assemble the selector links according to instructions?
I dont think the problem is in the gear ratios...
Old 04-02-2012, 03:54 PM   #7 (permalink)
I did this adaptation many times without problems and it is not helpful.
It's doesnt matter if I try put on the 5th in manual or in automatic, anyway I can drive 2 seconds on 5th and then I have no gears, no reaction when I move the gear shift, the clutch do not pulls.
selector is assembled good.
Old 04-03-2012, 01:09 AM   #8 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
ok now I could believe that the problem is inside your ECU. It might have been programmed that with fifith the RPM`s should be something at certain speed. If you have too much variation it might protect itself and change to neutral :/.
What gear ratio did you put in and what is the percentage difference between the two gears?
Lupo 3L gears are:
1st 3,455
2nd 1,955
3rd 1,182
4th 0,813
5th 0,642 and If I remember correctly that is freewheeling
So your new fifth is probably too close to fourth etc :/.
Old 04-03-2012, 02:38 AM   #9 (permalink)
Is it possible to adjust it in ecu ?
Old 04-03-2012, 12:50 PM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
If the problem is in ECU program you have to go to some tuning shop who know what they are doing. With this I mean best of your country, so not the places where they just try to sell chipping but where they do also harcore modifications to cars.
I believe the ecu thinks you dont have any tooth there because the rpms are so low or something. You could also try to ask VW is they have had any similar problems. For that you need to have a friend in VW dealer because they are not going to give that information to clients.
If you find out what was the problem I am interested to hear because I have plans to install even taller gears on my Lupo...
