Old 04-27-2014, 12:23 PM   #1 (permalink)
Cracker - '90 Honda CRX HF
New CRX owner
Hello all! I am actively joining after buying a 1991 CRX HF with 193k on it. Needs a bunch of things and I plan on restoring it as time goes on. Hope to have input as I get things done on this gas sipper.
Old 04-27-2014, 01:52 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder !
Old 04-27-2014, 08:59 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Congrats on the HF purchase - fun and efficient project.
Welcome to the forum!
Old 04-27-2014, 09:30 PM   #4 (permalink)
suzi - '93 Suzuki Sidekick glx
recycler - '93 Honda civic ex-s
Toyota - '09 Toy Matrix base
gigi - '04 Honda Element EX
Welcome-Rock Auto is a good place to checkout. Just starting to overhaul my 91 ef hatch.
Did you know early 1986 hf's had only 1 compression ring and one set of oil rings per piston? I am only pushing 70 hp pre mod.
Old 04-27-2014, 09:46 PM   #5 (permalink)
Yes, about to get an engine mount, valve gasket, and plugs for less than $50 shipped.
Old 04-27-2014, 10:27 PM   #6 (permalink)
Glad to help and advise. THX
Old 04-28-2014, 05:52 PM   #7 (permalink)
I love the CRX. The HF has those crazy wide gear ratios right? Or maybe that is another trim. I will always have a soft spot for the CRX
Old 04-28-2014, 06:13 PM   #8 (permalink)
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
Yeah the hf is the one! I bought one and am still working on getting my first base tank
Old 04-28-2014, 08:14 PM   #9 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Do you know if you have the Cali transmission with the 3.250 final drive or the 49 state version with the 2.95 final drive? Both versions had like a 0.690 fifth gear (approx). But if you have the 49 state 2.95 you have by far the tallest gearing around.
Old 04-28-2014, 10:12 PM   #10 (permalink)
trans
Not certain but I should have the 49 state trans and the 49 state ecu. I also want to install an air dam, front radiator blocks, rear diffuser, pizza pan wheel covers, Wheel spats, WAI, and someday I'll probably swap it to the D15Z1 after I've collected the swap and rebuilt the engine. One thing at a time!
