Old 06-13-2014, 03:08 PM   #1 (permalink)
Sylvie - '13 Nissan Sentra SR
Hello from up north
Hi,
New to the forum. Gotta say, what you are all doing here is inspiring.
While shopping for a new car last fall, I stumbled on this forum. I have lurked around for awhile and thought it was time to introduce myself.
I bought a 2013 Nissan Sentra 1.8 CVT (SR trim) in November.
After reading the tips, and trying to apply them to my driving habits, I've been able to get my fuel consumption down to 5.5L/100km.
Where I live(Winnipeg MB, Canada), the winters are brutal. Very cold and very snowy and icye winter and my consumption was around 8.5-9 L/100KM. The CVT just would not "downshift" in the winter. I was driving at above 2000rpm for 20-30 minutes before the engine would warm up. It was frustrating, but I don't think there's any way around it.
Any thoughts or comments, or tips on the winter RPM issue would be appreciated.
Cheers,
Gremlin
Old 06-13-2014, 03:11 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Gremlin,
Welcome!!!
others will jump in on the snow issues....
But think about getting a scanguage to give instant feedback(see link in my sig)
and bump up the tires to 40+ psi.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-13-2014, 03:14 PM   #3 (permalink)
Welcome to the site!
Instrumentation is always a great place to start. You don't know if you're doing better or worse unless you can measure it.
Next, I'd recommend blocking up your grill for sure. In winter, you can probably block most of it off without any issue. This'll help your engine and transmission warm up faster.
After that, I'd look into getting a block heater. That gets you warm even faster.
Old 06-13-2014, 03:16 PM   #4 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Eh
Welcome aboard
The Following User Says Thank You to mikeyjd For This Useful Post:
Gremlin (06-13-2014)
Old 06-13-2014, 03:29 PM   #5 (permalink)
Ya, all cars are sold with block heaters up here. I like the grill blocking idea though. Thanks for the tip.
The car came with a consumption display, but are those not to be trusted? Perhaps I'm getting better or worse than what I think.
Old 06-13-2014, 06:18 PM   #6 (permalink)
The Rental - '13 Hyundai i30
90 day: 37.55 mpg (US)
Autocross - '04 Ford Focus ZX3
90 day: 24.76 mpg (US)
The Wifes - '02 Ford Focus SVT
90 day: 23.54 mpg (US)
ahhh Winter-peg.
some times the oem in car displays are not very accurate. so, use it only as a ball park and to see improvments or declines. Hand calculating fuel economy when you fill the tank is the most reliable way.
when its doing that high rpm thing, would the rpm drop if you let off the gas? or would it engine brake?
Old 06-13-2014, 07:13 PM   #7 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
In addition to the grill block, there are a few other things people on this site have done (and you can look up using the search function): an undertray (or bellypan) which would keep cold air out of the engine bay during the winter as well as help aerodynamics), engine bay insulation, and duct the remaining opening in your grill to feed forced air directly to your radiator. Oh, and an oilpan warmer!
Old 06-13-2014, 08:14 PM   #8 (permalink)
darcane's Avatar
Cheers,
Gremlin
What does "Very cold" amount to in Winnepeg? -25°C? -40°C? At extreme cold temps, conventional oils get extremely viscous compared to synthetic. Research synthetic fluids for the CVT if you don't already use them. (Not sure if there are any problems that would arise from that, I never owned a CVT car). On a manual transmission at -40, I've stalled my engine (350 V8!) in neutral because the conventional tranny oil was so viscous.
Attaching an adhesive mounted heating pad to the tranny may be a wise idea.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
