Old 08-18-2010, 04:55 PM   #61 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
It also had "hard" shoulders (which I've since learned are to be avoided).
Why is that? My current kammback has hard edges, so what should I look for in the second design?
In Reason we Trust
Old 08-18-2010, 05:10 PM   #62 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
hard edges or shoulders?
Sharp cutoffs at the rear are generally a good thing (short of a complete taper). A rounded body shape is better for good aerodynamics, think of the cylindrical fuselage of a passenger plane. Darin is referring to the bends or creases in the cardboard where it turns down on the sides of his hatchback. It would be somewhat better aerodynamically if those were more rounded. If the air pressure on the sides is not exactly the same at that coming over the top, rounded shoulders can allow those to equalize a little. Sharp shoulders can be vortex generators which increase turbulence and drag.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
MetroMPG (08-20-2010), Piwoslaw (08-22-2010)
Old 08-18-2010, 08:21 PM   #63 (permalink)
AeroModder's Avatar
Team Ford
I see, thanks for the clarification.
In Reason we Trust
Old 08-24-2010, 07:48 PM   #64 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
ABA Testing update:
Kammback data:
Graph:
This seems to me to match pretty well with the coast down data from before.
The Following User Says Thank You to Weather Spotter For This Useful Post:
theoteacher (09-25-2010)
Old 08-24-2010, 08:05 PM   #65 (permalink)
Wiki Mod
More picts of car now that it is painted:
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
Piwoslaw (08-29-2010), theoteacher (09-25-2010)
Old 08-28-2010, 02:09 PM   #66 (permalink)
Oem
It's 'seamless',looks like OEM from parts department! I don't know how onlookers wouldn't think it was just a 'factory' car.Realy nice!
Old 08-28-2010, 02:52 PM   #67 (permalink)
Wiki Mod
Thanks for the complent!
up close you can tell that it is home made, but not without looking hard
Old 09-12-2010, 07:47 PM   #68 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I agree weatherspotter. You did a nice job of integrating your modifications. Sometime take a nice 3/4 view.
I hope I can do something like that for my camo minivan.
Noah Webster, 1787
Jeep Cherokee "Aeromatics" (Kammback / partial boat tail) JeepNmpg2 Aerodynamics 74 03-10-2012 12:49 PM
Designing a partial kammback on a sedan AeroModder Aerodynamics 37 01-31-2012 09:54 PM
2009+ Honda Fit - ideal rear design for Kammback MetroMPG Aerodynamics 16 01-28-2012 03:50 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 07:07 PM
Partial Kammback prototype tested - preliminary results MetroMPG Aerodynamics 8 11-28-2007 09:51 AM
