08-15-2010, 03:22 PM
#41 (permalink)
Wiki Mod
I would like to take the credit but I can not.
I saw it on 5gen civic hatchback thread:
http://ecomodder.com/forum/showthrea....html#post8636
At first I did not want to mess with it. It turned out to be very easy to remove.
For the top I used the bolt holes that heal the OEM spoiler on (it still opens like normal too)!
08-15-2010, 03:28 PM
#42 (permalink)
Wiki Mod
Originally Posted by COcyclist
Spotter, Thank you for posting your careful test data. I hope you do not find a 1% mpg increase discouraging. It is a step in the right direction. Darin (MetroMpg) has said there is no magic bullet; it's more of a magic buckshot approach, a percent or two here and a percent or two there and it all adds up.
I envy your simple and reversible construction method. I made a similar one of coroplast for testing but I don't have easy attachment holes. Do you have scraps left to make flat coroplast wheel covers? Perhaps in the future you can extend your Kammback for a longer, removable tail. I have welded up a bracket that fits in my receiver hitch for this purpose but that is as far as I have gotten so far.
I agree that the %%%% add up over time!
I do have several pieces left over, I am thinking about wheel covers, not sure if they are worth the risk of unbalancing the tires.
I also had thought of using my towing hitch for making a boat tail support. I am not sure if I will make one though. If I like the Kammback I might make a longer one (or just add onto the length of this one). I can add another brace running across the top and sides (attach at the shock mount brackets). I would also extend the braces coming from the top (bolts where the OEM spoiler was). This would let me make it longer in a modular fashion and who knows where it will end uphttp://forum.ecomodder.com/images/smilies/biggrin.gif .
08-16-2010, 12:54 AM
#43 (permalink)
Wiki Mod
I should have a good data set this weekend to compare with and without the mods. I have to travel the same 600+ mile round trip that I did a month ago. I do not know if the conditions will be the same, but it will interesting to see how the mods work on a long trip!
08-16-2010, 01:11 AM
#44 (permalink)
Pokémoderator
Weather Spotter -
Oh yeah, hee hee hee. I forgot about AndrewJ's hatch. It's still cool to see another working example and a compliment to the originator.
When I've tried to find pre-existing spots on my wagon to exploit, they just don't seem to add up.
CarloSW2
08-16-2010, 07:48 AM
#45 (permalink)
aero guerrilla
Sweet
I may be seeing it wrong, but it appears that the sides of your Kamm don't converge:
Compare to mine:
I believe this would help you reduce the Cd even more.
08-16-2010, 09:46 AM
#46 (permalink)
Wiki Mod
They actually do curve inward, not a lot but they do. I tried to keep the angle close to what the car had to start with (more but not a huge amount). I Would have made it more but my source colorplast was only so big, to curve it any more would have required a second splice. I also found it hard to make a radius curve and angle it in at the same time.
08-16-2010, 09:51 AM
#47 (permalink)
Wiki Mod
Originally Posted by cfg83
Weather Spotter -
CarloSW2
I Google your car, the hatch looks devoid of mount points. Have you seen if you can wrap a thin piece of metal around the top lip and fasten on the inside (like to the hinges)?
08-16-2010, 12:10 PM
#48 (permalink)
Aero Wannabe
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
08-16-2010, 01:14 PM
#49 (permalink)
Pokémoderator
Weather Spotter and COcyclist -
I do have hinges on my wagon similar to what Orange4boy has :
However, in my case I don't have the lower mount point, I only have the upper hinge.
I know it can be done, but my investigation implies that I could get in over my head really fast. There aren't enough screws to take stuff apart, so I think I would end up destroying gaskets that would be hard to get for my out-of-production SW2. What I *should* do is go to a pick-a-part and see if I can find another rear hatch at a low price. Then I could dismantle it at my leisure.
CarloSW2
08-16-2010, 01:30 PM
#50 (permalink)
Wiki Mod
the lower one can just be a stand off with a lip going under the lip of the hatch. As long as the top is attached the bottom is just there to hold the angle. You could just run a piece down to the hatch and put some rubber on it so it will not scratch.
