Old 05-20-2015, 08:46 PM   #51 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Thems some good figures!
54+mpg in Edinburgh with all the usual myriad of tribulations is great for a first tank- I reckon you'll be up to circa 60 in another tank or so
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
The Following User Says Thank You to 320touring For This Useful Post:
Arragonis (05-21-2015)
Old 05-21-2015, 06:14 AM   #52 (permalink)
The PRC.
Maybe. Having filled up yesterday I had the worse "going to work" average this morning at 48. The Stop-Start didn't work until I was nearly there and the RPMs were higher - I suspect a DPF regen and the "glide" MPG was down too (the DIS only shows up to 200).
Then again the A6 would struggle to break 30 some mornings, and on "DPF" days barely 25.
Old 05-21-2015, 07:20 AM   #53 (permalink)
I was thinking about something like this:
A turbocharger developed specifically to enhance fuel savings at the same time that it improves the throttle responsiveness and low-end torque.
Old 05-21-2015, 06:41 PM   #54 (permalink)
The PRC.
The issue is more torque vs. gearing than throttle response. I took Henning for a trundle through some country roads the other day and it was fine. But in 6th at anything under 80 is cruising only. Hills or lane changing means a shift to 5th or 4th. The motorway limit here is 70...
Old 05-22-2015, 06:19 AM   #55 (permalink)
In that video, one of the claims was that drivers could keep a longer gear in places where they would otherwise have to shift to a lower one, due to the improvement in low-end torque (which also ends up enhancing the throttle response as a bonus).
Old 05-22-2015, 03:50 PM   #56 (permalink)
The PRC.
But which one uses more fuel, a quick downshift and a pulse or longer time on boost ?
Old 05-22-2015, 04:09 PM   #57 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Diesel engines usually have their max BSFC at a low rpm. I would lean towards keeping it in high gear and finessing the throttle. Of course, the only truthful answer will come through real world testing.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 05-22-2015, 06:49 PM   #58 (permalink)
The PRC.
Yep, will do. But lay your bets....
Old 05-24-2015, 02:06 AM   #59 (permalink)
One of the keys to get some nice mileage figures in a Diesel is how quick they get into their optimum temperature, and to keep it constant. Some commercial drivers in my country use to go a little harder on the throttle for a while right after the start just to increase the temperature. I'd rather use a grid heater or some sort of heat exchanger to recover some ehaust heat.
Old 05-24-2015, 12:59 PM   #60 (permalink)
The PRC.
Pondering a sump heater for the winter, just now the needle is moving by the time I'm at the end of my road, which is about a mile of mostly downhill coasting. Stop-Start kicks in when I stop there too.
