06-14-2021, 01:41 PM
#111 (permalink)
Mechanical engineer
If someone wants to test wheelcover savings easy in their car this is the way to go:
https://youtu.be/dHMWk8llX-E
The Following 3 Users Say Thank You to Vekke For This Useful Post:
06-15-2021, 06:59 AM
#112 (permalink)
Originally Posted by Vekke
I must admit I am at a bit of a loss.
Covering the wheel trim in (what? sticky cling film?) doesn't to me equal "If someone wants to test wheelcover savings easy".
Like, how do you then test the savings?
If I have misunderstood and it's just about covering wheel trims, well, just packaging tape would do that.
As I say, maybe I have missed the point?
06-16-2021, 12:52 PM
#113 (permalink)
doesn't to me
1) I don't believe the video goes beyond a simple means of providing a flush, full-coverage wheel cover.
2) a single piece of material/ wheel, vs many overlapping pieces of packing tape, or zip-tied 'janky' cardboard covers, pizza trays, etc..
06-16-2021, 01:33 PM
#114 (permalink)
Cyborg ECU
Looks great, Vekke. That book wrapping laminate is pretty vigorous. Certainly enough for mere testing. Clean and quick. We could use other tape, but it you have access to sheets like this, it is faster and easier. Also, clear means you are relatively inconspicuous. I like that too.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
06-16-2021, 06:10 PM
#115 (permalink)
OK, it was what Vekke wrote that had me confused then. He said "If someone wants to test wheelcover savings easy in their car this is the way to go".
Of course, this isn't a way of testing wheel cover savings at all; it's a way of covering the wheel with plastic sheet.
How one then tests the saving (or otherwise) resulting from that is, to me, the important question.
06-16-2021, 06:29 PM
#116 (permalink)
OK
I, for one, appreciate the clarification.
06-16-2021, 07:20 PM
#117 (permalink)
Perhaps Vekke would appreciate some friendly persuasion? Instead of, you know, pushback?
06-16-2021, 09:01 PM
#118 (permalink)
I don't know, Freebeard. I just go on what is written, and I honestly thought that we were potentially looking at a new way of measuring "wheelcover savings" - something that is very, very hard to do in the real world. I was therefore a bit disappointed that it turned out to be just a way of wrapping a wheel.
06-16-2021, 09:27 PM
#119 (permalink)
Disappointment in life? You'll get used to it. I'm still disappointed that you capitalize my handle.
Vekke made a post on the 14th showing a 'way to go'. Today is..... 'Today'. Maybe Vekke won't come back to the thread to share what he's doing. I'm impressed with his meticulousness. I'm in no position to second-guess the results.
06-16-2021, 09:40 PM
#120 (permalink)
I think we've had this discussion before, but you should look really closely at how Vekke is measuring his energy consumption results.
From what he has posted here, he is doing a 3 minute run in each direction at 100 km/h, taking 5 instantaneous energy consumption measurements each way.
And then claiming he can measure aero variations down to 0.6 per cent.
Just apply that idea to measuring fuel consumption of an ICE car using the instantaneous fuel consumption readout... and try to get repeatable results with the car in exactly the same configuration. You won't be able to.
I am concerned that if the testing methodology is as bad as that, and people (maybe like you?) are not looking at how it is actually being done, then any results he gets are likely to be highly misleading of others.
