Old 06-06-2010, 11:23 AM   #1 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
Talking 2010 Nissan Cube in the neighborhood!...
Just joined up here last night after browsing the forum for a few days. Found it via GasSavers.org in fact.
As it says in the title, I have a Cube that I bought new back in January. I drive roughly 112-118 miles a day, 100 miles on the highway and 12-18 in town. It had 50 miles on it when I got it, now I'm at 12,080 miles. I've been running Amsoil Signature in it since 8k miles. I did the first oil change at 900 miles with regular oil, then again at 3000 miles. I switched over to the Amsoil Signature 0W20 at 8000 miles. Somewhere around this time, I also replaced the stock 15x6 steel wheels to aftermarket 15x7 aluminum wheels. The stockers weighed in at 15.6 lbs each. The new ones weigh in at just over 12 lbs each. It's not a major improvement, but it was a noticeable improvement in acceleration. I'm running the stock Toyo A20 195/60-15 tires which Nissan claims are LRR tires, which oddly enough I can not find any information on, even on Toyo's site!
Since browsing both forums, I've applied a few tips to my driving style and my Cube. For the Cube, I first raised the tire pressure from the recommended 33psi up to 40. I didn't notice much of a change if any, so yesterday I bumped them up to 50psi. The max sidewall is 51. After bringing them up to 50psi, I noticed an improvement in ride quality (I like a little firmer ride), but it's also smoother if that makes sense, turn-in is crisper, and steering input feels better. I can tell that it takes less effort to start rolling and that it wants to roll on its own longer now.
I just ordered a 10 pack of VG's that I'm going try, just to see if they do anything for my car. I'm also going to try changing my driving techniques to get better FE. I'm going to start looking into adding some tire/wheel spats front and rear, possibly even adding some paneling under the front and rear bumpers to smooth out the air flow. I'll eventually lower the Cube too, about 1.5" all around. I might even look into making the fog light "cups" smoothed out flush with the rest of the bumper, or remove the stock covers and make some kind of engine compartment or brake vents/ducts out of them as well as possibly doing a partial grill block.
Old 06-06-2010, 02:26 PM   #2 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
glad to see another nissan on board! Turns out there are quite a few of us Nissan owners here.
You'll hear it eventually, so if you get a scanguage it'll help out a ton. the ton of info available from the thing is astounding.
Here's an interesting article for you.
Nissan cube
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 06-06-2010, 02:47 PM   #3 (permalink)
ChopsQube's Avatar
Thanks for the welcome!
I do in fact have a Scan Gauge II. I've used it in a total of three different vehicles now and it was installed in the Cube the same day I brought it home.
Also, I've seen that article already, as well as just about any other article out there about the Cube as there's aren't many.
I just wish there were more Cube's on these "eco" forums.
Old 06-06-2010, 02:51 PM   #4 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Welcome! Looking forward to your fuel logs. My wife really wants a Cube, and I'd be interested in seeing how it does FE-wise.
Old 06-06-2010, 03:04 PM   #5 (permalink)
ChopsQube's Avatar
Well at the moment, I'm getting an average of 26.8mpg. But now I'm running much higher tire pressure and am in the process of changing my driving techniques, so I'm hoping to see some improvements in the next few tanks.
And now that I can add some pics, here's the Cube...
And here's the SG II in my last car, a 2002 Miata 5-speed...
And before that, an 2002 Chevy Blazer 5-speed...
Old 06-06-2010, 04:02 PM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I've added the Cube to our Vehicle Drag Coefficient Wiki. Cd = 0.35, CdA = 9.48ft².
Most of your energy is spent overcoming aerodynamic drag, so your biggest gains would come from reducing your cruising speed or improving your drag coefficient.
After a few stealthy mods, your ability to lower Cd without drastically altering the character of the Cube will hit a wall. Those stealthy mods include wheel covers on the inside of the wheel, a grille block behind the grille, and underbelly work if Nissan overlooked any. Beyond that, maybe you could work in some quirky looking rear wheel skirts. Unfortunately, cubes (not Cubes) have fundamentally bad aerodynamics, especially at the rear, that can not be cured without taking much of the cubicness out of the Cube.
Old 06-06-2010, 04:31 PM   #7 (permalink)
ChopsQube's Avatar
Actually, I just figured out the CdA of the Cube a couple hours ago and it's not 9.48, it's 8.51.
I figure if guys with the original Scion xB's can get 35-45mpg, there's no reason why I can't. Aerodynamic wise, they're about the same. Even the new xB's aren't much better.
I've got some VG's coming my way just for the heck of it, but no way am I putting fender skirts on my car, not to mention they wouldn't fit over my rear wheels anyway. I'll try installing some tire spats though.
Old 06-06-2010, 08:25 PM   #8 (permalink)
Left Lane Ecodriver
Well, here's my method. That's height times width times Cd times packing factor. The only one I didn't google for was the packing factor, which is a guesstimate. 0.84 is what I usually use for most sedans, wagons, and trucks, but I figure the Cube fills out its frontal area a little better than most.
With a p.f. of 0.84, you get CdA = 8.85 ft².
I don't like picking on the newcomer, but I would like to hear where our calculations differ.
In any case, it's got aerodynamics somewhere between that of a minivan and a midsized car.
Old 06-07-2010, 12:03 AM   #9 (permalink)
ChopsQube's Avatar
I believe I read in your "CdA list" thread that you multiply by 0.81...
Width = 66.7" = 5.56ft
Height = 65" = 5.42ft
Cd = 0.35
5.56 * 5.42 * .35 * .81 = 8.54
CdA = 8.54 ft^2
Is the Nissan Cube the Future of Transportation? SVOboy EcoModder Blog Discussion 17 06-18-2010 12:56 PM
2009 Nissan Cube PaulMedley General Efficiency Discussion 5 11-27-2008 01:03 AM
LA Auto Show: Nissan, 370Z, Cube, etc SVOboy EcoModding Central 1 11-20-2008 01:41 AM
News: Nissan to launch electric car in US by 2010 MetroMPG Fossil Fuel Free 6 03-07-2008 05:18 AM
Dan Neil for president! (LA Times Nissan Cube review) MetroMPG General Efficiency Discussion 2 01-30-2008 01:03 PM
