Old 04-08-2012, 01:44 PM   #1 (permalink)
Del Slow - '94 Honda Del Sol Vx
90 day: 42.31 mpg (US)
Honda Del Sol 50MPG goal
Hey econo friends my name is Carlos I have been modifying cars for 8 years but mostly trying to make more horse power not to worried about MPG my CR-X only got 20-25 MPG I have played with MPG in the past and only got 40mpg in my 97 civic coupe with a integra LS 1.8L motor I recently got a job that is 35 miles away and finally tested my Honda Del Sol first week I got 34MPG second week Im at 38MPG with wiper delete and reduced my speed 5MPH I do have full functional A/C and not getting rid of it
Future mods I bought a civic Vx transmission and grill block off and my friend has a body shop and will be deleting Auxiliary lights and rolling my fenders like the Honda insight
Pictures coming after five post
Old 04-08-2012, 11:29 PM   #2 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Welcome! We love Honda's here! Your prior CRX was an SI??? Pretty bad for a CRX
unless you were always standing on it!
My best w my '87 is 62.9 mpg so far.
I'm sure, w some patience, and work; you CAN reach that 50mpg w your current ride.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 04-09-2012, 12:41 AM   #3 (permalink)
It was an Si fully built integra GSR motor 13:1 compression and here is my Civic Wagon with same setup
My wagons motor
Here is my CR-X with winter tires and wheels
And last my Honda Del Sol
Old 04-09-2012, 12:51 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wagonef8 -
Welcome to EM! This fellow sold a Del Sol with a Honda VX drivetrain back in May 2008 :
http://ecomodder.com/forum/showthrea...1-vx-4000.html
Don't know what happened to him, but your thread reminded me of his achievement.
CarloSW2
American Solar Energy Society
Old 04-09-2012, 08:50 AM   #5 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
50mpg is more than doable. In 2006, krousdb aeromodded a Del Sol and averaged 58mpg from it. If you search back through Cleanmpg and Gassavers, you can find some of his old threads about modifying his Del Sol. Below is his thread about installing the underpanel on his Del Sol:
Del Sol Aero Mod - CleanMPG Forums
aerocivic.com
Old 04-09-2012, 09:05 AM   #6 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Just a thought, what cams do you have in your engine? Do you have adjustable sprockets?
My idea would be to put the stock USDM cams back into the motor and adjust the VTEC kick in point so that it would come on later, then get a J&S Safegaurd knock controller to mind the store when it comes to detonation. Good thing that Hondas are pretty good when it comes to cylinder head design.
I had thought about doing a Honda like this, but with a D series VTEC. All the VX mileage goodies but a lot of compression, pump gas or E85, and a custom ground cam. The low speed lobe would make more bottom end torque than stock so that it can be short shifted around, while the high speed lobe would be about the same as stock but with a little more lift. I asked the cam grinder if he could do something like that, he said "Sure".
Initially, I wanted a more Jeckyl and Hyde grind that would be do what I described above with an 8500 rpm high speed lobe, but he said the transition might be schizophrenic. Now that I think about it, I wouldn't mind that. As long as the engine is above 3500 rpms it shouldn't matter.
But all that got thrown out the window as of yesterday.......... a neighbor just offered me a FREE Toyota 2TC mini hemi 1.6L 4 cylinder out of an early Corolla. Life just got interesting!
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 04-09-2012, 09:52 AM   #7 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Good luck!
Do you have FE instrumentation?
Old 04-09-2012, 10:18 AM   #8 (permalink)
The good thing about Honda's is they are versatile you can achieve 11:1 and 12.5:1 compression with a combination of stock parts
Old 04-09-2012, 03:00 PM   #9 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
50 MPG from a del sol should be within reach. I remember when I had my 93 Del Sol S I could hit 38-40 MPG at a speed of 70 MPH if I didn't do too much city driving. Welcome to the forum.
1998 Honda Civic HX - My Project Thread
Old 04-09-2012, 09:33 PM   #10 (permalink)
Going to try really hard to get as close to 50MPG before swapping transmission got grill block off and mirror delete planed for this weekend
