07-21-2014, 01:43 PM
#11 (permalink)
Cyborg ECU
Originally Posted by dirtydave
Just put the fan on a switch to the dashboard.
That would be a solution, but he said at the beginning of the thread that he did not want to do that. (Might have to, anyway.) Hey, now that you know the wiring and how to turn on/off the fan... why not get the relay and wire it in?
07-21-2014, 01:45 PM
#12 (permalink)
Not bad for a machine
Originally Posted by War_Wagon
. Ah, dealing with 24 year old economy cars that have been hacked together to keep them running over the years, is there anything I'd rather do with my time?? ha ha
Not me!
07-25-2014, 05:56 AM
#13 (permalink)
Too many cars
The radiator fan switch should be to the left of the oil pressure switch in your pic. There are some pics in these threads.
CIVIC4G.COM - Honda Civic 4th Generation (1988-1991) Forum
z6 coolant flow diagram - D-series.org
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
07-25-2014, 11:27 AM
#14 (permalink)
Cyborg ECU
Originally Posted by Gasoline Fumes
Yeah, that's an interesting discussion you linked. The OP there seems to say his D15b block has that port blocked-up. He does not say which D15b he has. He seems also to suggest he has the JDM. Maybe the USDM Civic base model D15b1 has that fitting plugged? Maybe the CX came with the D15b1?
07-25-2014, 12:15 PM
#15 (permalink)
Cyborg ECU
Oh, and what the hell... here is a guy at Honda Tech suggesting the switch location and wiring harnesses changed from engine to engine across the D15b blocks... also suggests "plugging up" the fan switch port on the block for a guy completing a swap. ... http://honda-tech.com/showpost.php?p...0&postcount=63
07-26-2014, 12:53 AM
#16 (permalink)
Too many cars
Here's a pic I took of a D16A6 in an AWD Civic Wagon at the junkyard.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
07-26-2014, 01:18 AM
#17 (permalink)
Too many cars
My D15B2 has the same sensors. I can't understand why some engines wouldn't have the same switch. Maybe some are being broken off while wrestling out an alternator?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
07-26-2014, 02:42 AM
#18 (permalink)
5 Gears of Fury
Well I don't know what to tell y'all. There's no sign of a switch for the fan on the back of the block next to the oil pressure switch, like all the diagrams would have me believe. Someone cut 2 wires off the factory harness at the back of the block that when wired together keep the fan on full time. I don't know what version of the 1.5 my car has, I just know it is a Canadian model '90 CX, which would be equal to a US model STD. So I am guessing it's whatever the most basic model 1.5 you could get was. I am also guessing that the wires were cut at some point because someone else got confused by this whole deal and wired in a switch when they couldn't figure out what was broken. I can't say I blame them.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
